![]() Drives: Chevy Camaro ZL1 Join Date: Oct 2020
Trunk release on ZL1 1LE with no battery
Hi all,
So I had one of those moments today. I had disconnected the negative battery cable in the truck. Some time later, I accidentally closed the trunk, so now it will not open. Given that this is a ZL1 1LE, the back seats are fixed. Any one know how to open the trunk now? I called the dealer and they mentioned about a hole in the back seat behind the driver but I cannot find that darn hole. The service person has not seen it before either? Any help appreciated. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL-1 Join Date: Feb 2009
Fold back seats down, crawl into trunk and pull glow in the dark handle for trunk release.
2012 Yukon XL Denali w/ 6.2 AWD |
![]() ![]() ![]() Drives: 2017 Silverado/2017 ZL1 Join Date: Aug 2019
can you hook up another battery to the terminals in the engine compartment to get enough voltage to pop the trunk? wondering if that would actually work with the battery not connected lol.
ZLE doesn't have foldable back seats
I tried with the battery terminals but nothing. I will leave the tender for a little longer. Does it make a difference that I disconnected the negative cable from the battery?
![]() Drives: 2017 Bright Yellow ZL1 6spd Join Date: May 2010
A battery tender is a trickle charger. If your battery is that dead, it's going to be a while before you can bring the battery up enough. If you have a regular battery charger, or a car that you can jump from, you'd be better off.
To clarify, the battery is fine, I just disconnected the negative cable from the trunk (to replace the cluster).
#7 |
yes, this. trickle charger is doing nothing since its not charging a disconnected battery. You need to add voltage from a fully charged battery or another vehicle. Even so, I am not sure if using a fully charged outside source will work but its worth a try.
#8 |
I will try that. Thank you everyone for the suggestions
#9 |
let us know if it works.
#10 |
![]() Drives: 2022 Wild Cherry ZL1 1LE Join Date: Mar 2021
Oh interesting... So there is no key hole at all on the trunk, not even a hidden one right above the license plate? Ouch!
As a note, about ZLE backseats, my understanding is that you *can* fold them down, but the button is only accessible from within the trunk. This video shows how to do it: How to fold seats back on a 2018 Camaro ZL1 ![]() Geoff |
#11 |
![]() ![]() ![]() ![]() Drives: 2018 Camaro ZL1 Join Date: Aug 2018
Yes. The seats can be folded down but for some reason GM took the strap away.
Just get a strap and attach it to the mechanism so this can be easily avoided next time. Just hook up to the front terminals under the hood and there will be enough power to pop it. Do just like you would if you were jumping a vehicle off. |
#12 |
That did it!!
Thank you all. I hooked the car to another running car and I was able to open the trunk. Who knew it is so complicated to open the trunk (even the dealer basically said I have no idea :( ). Thank you all for the help. I will look into the straps for the back seats, but hopefully there is no next time
#13 | |
Thank you Al Oppenheiser!
1. Remove metal physical key from the key fob. 2. Use it to pry the cover off the fixed portion of the driver's door handle (take care not to scratch things). 3. Then use it again to open the car. 4. Pop the Hood. 5. Connect a 12v source to the jump posts at the fuse box. 6. Push the trunk button on the driver's door. |
#14 | |
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
Or you just take the 10 seconds to fold the rear seat down and open it from the inside
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
