Old 04-20-2021, 08:23 AM   #1
Swift016
Swift016's Avatar
Drives: 2019 ZL1 1LE
A10 problem
Guys,
I have a 2019 ZLE A10 with 15,000 miles.
Recently , I’ve noticed what feels like a clutch slip when an auto shift from 2nd to 3rd from a stop.
I only notice this when the car is cold, and it goes away when the car is up to operating temp.. it feels like a clutch slipping on a manual transmission.
It doesn’t seem to be affected by how hard I’m accelerating... normally, I’m light on the throttle since everything is cold
Any ideas ?
Thanks,
Bill
Swift016 is offline   Reply With Quote
Old 04-20-2021, 12:46 PM   #2
Vigilante375
Drives: 2018 Camaro ZL1
Mine does the same. I even had the fluid replaced a few thousand miles ago and it's still there. The fluid was replaced because it was time to do so.
The 2-3 and 3-4 shifts in this car are rough compared to the others. Don't know why but that's the way it is when you're just driving around like a normal person.
Old 04-20-2021, 02:11 PM   #3
Akura
Akura's Avatar
Drives: ´18 ZL1 A10 Red Hot 😍
Can you explain if they did a flush or changed the oil downloading the pan? Thank you.
First ZL1 in Spain (Madrid)! Red Hot, A10, PDR, carbon fiber hood & grounds effects...
Akura is offline   Reply With Quote
Old 04-20-2021, 02:44 PM   #4
Vigilante375
By taking the pan off. I would have done it myself but GM made it kind of a pain. You technically need a software to make sure the transmission is up to temp then press into a drain port until it stops draining....all while the car is level and lifted up enough to get under it.
Old 04-20-2021, 06:35 PM   #5
tmak90
Drives: Camaro ZL1 1LE
I have also noticed this on my A10 when car is cold and not even really pushing it at all. Mine only has about 14,000 mileage and sometimes have a slight delay when upshifting from 3 to 4th and sometimes feel a slight slippage in the gear transitioning.
tmak90 is offline   Reply With Quote
Old 04-20-2021, 07:52 PM   #6
Village Idiot
Drives: 2019 Camaro SS
The A10 in my SS does the same thing. I brought into the dealer and they told me it’s a 10 speed, it shifts a lot and I’m not used to it. I almost lost my mind.
Village Idiot is offline   Reply With Quote
Old 04-20-2021, 09:40 PM   #7
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
you can use a cheap scan tool to monitor transmission temp and get it in the 200°F range to check for the correct "track level". It isn't hard but a bit weird because of the lack of a dipstick and fill tube, You must add fluid through the check orifice (10mm bolt) in the driver's front of a standard A10 pan or middle rear of a ZL1 1LE A10 pan. My '17 A10 and '21 A10 shift with nearly the same quality and firmness. It is a bit harsh on the 4-5 when cooler on track but is fine after the fluid gets warmer. Neither cars do any slippy feelings 2-3 in auto mode but I bet your situation is normal.
Old 04-20-2021, 09:58 PM   #8
Village Idiot
A10 operating temp is 200? I don't think I've ever seen mine get over 150ish, at least not on the temp gauge in the dash. And it normally takes forever to get there, almost 30 minutes.
Old 04-20-2021, 10:41 PM   #9
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Mines done this since new from 3rd- 4th cold/hot if i am very light on the pedal. The clutches just take longer to engange/disengage. If i am on the gas just a bit, it goes away.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 04-21-2021, 04:29 AM   #10
Akura
Akura's Avatar
Great info, thank you!
Old 04-21-2021, 10:28 AM   #11
Vigilante375
The range is 203 to 212 F. I wouldn't mind doing this but I don't have access to a lift plus with GM have no dip stick nor an easy place to fill the fluid just makes it harder for me.
Old 04-21-2021, 11:12 AM   #12
Stephen12ZL1
Drives: '21 ZLE A10
200 to check for track level only. You will almost never see more than 150-175 on the street
Old 04-21-2021, 06:21 PM   #13
Swift016
Swift016's Avatar
Guys,
Thanks for the feedback.... my car was not this way for the first 14000 miles. It only started recently... it is a definite change .., it just feels like a slipping clutch prior to engaging the next gear.... seems to go away when the tranny is warm.... only started doing
It recently..,
She’s my daily driver and track
Weapon, so I’m pretty familiar with her ..,
Old 04-21-2021, 06:47 PM   #14
Royal Dutch
Drives: 2021 Chevy ZL1 A10 Cpe Shadow Gray
if you haven't serviced the trans yet, do it and see what happens. If nothing changes, then you will know how to procced.
Royal Dutch is offline   Reply With Quote
