Old 04-18-2021, 07:28 PM   #1
SSallday
SSallday's Avatar
Drives: ‘18 ZL1 / ‘22 ZLE
Lift Required for Supercharger Removal?
My car has an appointment tomorrow for a supercharger replacement. Is there a reason why the dealer would need to lift my car to remove it? I know the instructions from GM may be different than what we follow. I haven’t installed my lift pads yet and I don’t want to make a “dealer damaged car while lifting” thread.
Thanks
SSallday is offline   Reply With Quote
Old 04-18-2021, 08:03 PM   #2
Jaxcam02
Jaxcam02's Avatar
Drives: 2017 Silverado/2017 ZL1
Probably just to lift it up a bit so the tech isn't bending over during the install. That would be the only reason I could imagine. Ask them if they have to use a lift that they use a roll on lift.
Jaxcam02 is offline   Reply With Quote
Old 04-18-2021, 08:21 PM   #3
7LitreC5
Drives: 18 Tahoe RST, 19 Z06
No need to lift. the work is all done from the top.
7LitreC5 is offline   Reply With Quote
Old 04-18-2021, 08:54 PM   #4
JD64
JD64's Avatar
Drives: '19 Camaro ZL1 A10 Riverside Blue
yep, lifting the car slightly definitely makes things more comfortable to work on.
JD64 is offline   Reply With Quote
Old 04-19-2021, 07:15 PM   #5
SSallday
SSallday's Avatar
Well, the car is at the dealer. I completely forgot to ask if they were going to lift the car, but I guess it doesn't matter at this point. Definitely going to install the lift pads before I take it in for service next time.
Old 04-19-2021, 07:32 PM   #6
Jaxcam02
Jaxcam02's Avatar
Why are they replacing the supercharger for?
Old 04-19-2021, 07:41 PM   #7
SSallday
SSallday's Avatar
It makes a loud "clacking" noise for the first 5-10mins on a cold start. They think it's the supercharger, which is what I thought initially. If this doesn't solve the issue then I think it might be the fuel line.
