![]() Drives: 2021 Camaro 1SS M6 Join Date: Mar 2021
No "Launch Control" on Competitive Mode (scratching head)
Hey guys, I've looked for a few hours on here-and got side tracked reading many many posts btw, but I can't find any info on my question of-Does Competitive Mode not include Launch Control on some 1SS models?
I hit my traction control button twice and "esc/Competitive Mode" reads on my screen, but I can't get it to "launch". I also only have 9 of 9 pages for the performance screen. I don't have the "Disabled" Launch Control screen. My car is a manual so I put it in track mode and hit t/c button twice for c/m and I have my car in first gear and the clutch all the way down, but when I slam on the gas it just revs towards 6k and does not stabilize to "set up" a launch. Just curious if my car needs a flash from the dealer or does my car/vin/model not have any launch control capabilities? Thanks
2021 Camaro RS 2.0Turbo SOLD
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
Does engine speed stabilize at ~4000 - 4500 rpm? Accelerator pedal to 100%?
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '16 Garnet Red 1SS Join Date: Mar 2014
Page 225 here:
https://my.chevrolet.com/content/dam...ro1stPrint.pdf
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
#4 | ||
Does line lock come on certain models whether auto or manual? Or just the 2SS?
Nah, I don't think there's anything like that. I've never used it personally. But it may adjust the RPM based on temp and junk like that.
'16 Camaro 1SS
#7 | |
Line lock was on the auto SS only, not the manual SS. 1SS/2SS wouldn't matter.
#8 | |
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: like an old lady Join Date: Jun 2012
be sure to firmly press the brake before you rev the car up.
#10 |
![]() Drives: 2018 Camaro 1SS Join Date: Apr 2018
You need to make sure you have the clutched pushed all of the way to the floor while in 1st gear and then mash the skinny pedal to the floor as well. It will rev up to around 5k then level off around 4300-4500. I actually tried it for the first time the other day just to see if it worked. It did.
Camaro 1SS M6 - LT2 IM, 1-7/8" Speed Engineering Headers & catless 3" x-pipe to Borla ATAK NPP axle back, Mishimoto Catch Can, BTR Rocker Arm Trunnion kit, E85, 95MM TB, JLT CAI, 180* T-Stat, & SJM line lock - Tuned by Ted Jannetty
#11 |
![]() Drives: 2018 Camaro 1SS 1LE Join Date: Feb 2020
In my 2018 1SS 1LE it seems super finicky, enough to make me question it like you are. It requires the steering wheel to be straight and the clutch pedal to be on the floor. It seems like the wheel has to be PERFECTLY straight and you have to be trying to push the clutch through the floor. When it does engage, you can tell right away. It also seems like the ground has to be perfectly level. I tried it on a road that had a very slight crown and couldn't get it to engage. The engine revs faster than the RPM gauge sweeps so there is a huge difference in the sound/feel when you mash the gas pedal between when Launch Control is activated and when its not.
#12 |
Thanks guys, I got it to work. The wife was in the car when I tried it. She's not big on the power-scares her, but she enjoyed the ride. It was a good launch with not much wheel spin so I'll have to try it again with the 0-60 timer. It is LOUD holding at 4300k rpms in track mode. But impressive with the technology from Chevy for that type of launch with a manual.
#13 | |
#14 |
![]() Drives: 2017 Camaro SS 1LE Join Date: Apr 2021
FWIW seems like magazines got quicker launches without launch control anyway - 2k RPM in the SS 1LE.
