04-15-2021, 09:22 PM | #1 |
Drives: '18 SS 1LE Join Date: Jul 2016
Cost to HP, IM or E85
Trying to decide on the next thing for my 1LE.
Currently have a Rotofab dry filter intake, 1 7/8 TSP long tubes with high flow cats, and a Pray ported 87mm throttle body I'm looking at the MSD Atomic intake manifold, but it seems like the LT2 intake manifold ported provides around the same amount of power as the MSD, and at half the price. Won't I need a 95mm throttle body then? With the LT2 as well as the MSD? I'm also looking at a flex fuel sensor and e85 tune. However, my 1LE is not my daily so I'm kind of paranoid if I leave e85 sitting in it, due to it attracting moisture. I've also heard some horror stories of people getting bad batches of e85 and causing pre-detonation and catastrophic failure. Do you corn fed guys typically test your E content before you fill up on e85? What is your opinion? Get an intake manifold, and also have to buy a 95mm TB? Or will my stock ported 87mm TB work with LT2 IM? Is there any worry with e85? As my car is NOT my daily? Power vs cost I guess, they both make around the same power increase.. Thanks for any input! |
04-15-2021, 09:27 PM | #2 | |
Drives: 2020 LT1 M6 Join Date: Jan 2016
04-16-2021, 07:00 AM | #3 |
Drives: 2018 Chevrolet Camaro 2SS 1LE 6M Join Date: Jul 2019
E85 is one of the best mods dollar/HP wise. 25-30 RWHP. I check my E content regularly on my datalogs. Here in California E content is 75-80%.
Bolt-ons.
04-16-2021, 07:38 AM | #4 |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
The E85 sensor adjusts for E85 content all the time, so no worrys there.
04-16-2021, 07:55 AM | #5 |
Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
Why not do a cam upgrade instead?
04-16-2021, 08:13 AM | #6 |
Drives: Chevrolet Camaro SS 1LE Join Date: Jun 2020
First thing I would do is look to make sure there are gas stations nearby that have E85. If there are then you're set. My car isn't my daily. It sits in the garage for a week at a time with no issues. Some of the guys in the colder environments have some issues cranking but being in Florida, that shouldn't be a concern. As far as testing it before I fill up, nah. My gauge tells me how much ethanol content it is. I've never gotten any bad batches before.
As far as intake and throttle bodies go. To me, it would depend on your future mods. I have the LT2 intake with a ported 87mm TB. The difference between the LT2 and the MSD wasn't enough for my build. My suggestion, just buy the intake and keep your throttle body. You're gonna need the coin for the tune. That was a massive expense between the actual tuner, the credits, and the tune. |
04-16-2021, 08:20 AM | #7 |
Drives: 2016 Camaro 2SS Join Date: Apr 2018
04-16-2021, 08:23 AM | #8 |
I'd do the 95mm and the Lt2 unless you have further plans to open up the motor at that point I'd do the MSD over the Lt2.
04-16-2021, 08:33 AM | #9 |
Drives: 2017 Camaro 2SS Join Date: Jul 2016
Haven't seen many impressive results with the ls2 intake so far but maybe I just haven't been paying attention. I went with a GPI ported msd/95mm combo and have been very happy. The TB is a no brainer as it can be had for $150 or so. The manifold is pricey for sure but with e70 in the tank I'm right at 470 rw so pretty happy with the results. Was stuck at 440 rw for awhile because I was running a crap tune, but then I found a good tuner on the HP tuners site and he got me straight for much less than the well known guys.
No worries about e85 as your ethanol sensor and tune take the guesswork out of it. Everybody likes to go right to the power adding mods but you should also consider a few upgrades that will help you put that power down. The rear cradle lockout kit from BMR is a great addition, even though the price is insane for what you get. Motor mounts are also an over-looked upgrade. The solid ones really limit engine movement and give the entire drive line a good, crisp, planted feel. I'd consider those as well.
2017 2SS A8 TSP LT's, ported msd/95 mm, e85
04-16-2021, 09:25 AM | #10 |
thanks everyone,
i had a cammed 5th gen before this. i do plan to cam this 1LE eventually. but im not ready for it yet. kinda deciding if ill be adding a blower in the future, so i might go with a boost cam. as for right now, im just looking for simple bolt ons. it seems like im leaning towards E85 now. Where are you guys running the E content gauge? does it tap into the fuel tank? where do you mount your gauges? im not huge on wiring, but an E content gauge as mentioned above might be nice. although the flex fuel sensor and tune will adjust for it. there really is no worry with leaving e85 in the tank for a period of time? ive seen some threads saying dont leave it because it attracts moisture to the entire fuel system. |
04-16-2021, 11:59 AM | #11 |
Geezer_loves_Camaros
Drives: 2018 2SS, Black, A8 Join Date: Dec 2018
I would agree with the others that E is the best overall mod/bang for buck. I don't daily mine either, i run only E, and have done so for the last year. During the "colder months" (relatively speaking for TX) and rain, i don't start or drive mine for a couple of weeks at a time. I've not had any issues thus far is all i can attest to.
There are different gauges for reading E, don't think any are a tank install. I think most are either wireless or connect to obd2. But I don't have one, so those who do can tell you more on that. |
