Kooks LT w/Green Cats to catback
Hey guys hope everyone has been keeping well during these times.
Currently I have installed kooks LT w/green cats, into factory exhaust and suitcase. Im interested in upgrading the factory system to aftermarket for more flow, due to upcoming cam, and pulley installation. My question is, Is there any connection issues from kooks green cats to say corsa catback, or awe, or borla in terms of direct fitment? or will modifications have to be made? |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
I was fortunate enough that I could slide my AWE cat back exhaust forward about 1" to make it connect to the Kooks connection pipes. You don't have a lot of room though and some may want their exhaust tips sticking out further so if you do that, you may need some very short connection pipes made to fit.
#3 | |
I may have to settle for the full kooks system or xpipe to suitcase at very least. Does anyone else have any experience with kook LT w/green cats. Truthfully I do prefer the corsa sound...... |
Yes, mine has Kook LT and green cats to stock cat back, sounds awesome
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO. 15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR. 100 octane: 1045hp/1055tq. 100 octane + Alky MAF Meth (1) 10+: |
#5 | |
I hope I can get some feed back on past installations : ie, filler piece required, or special type of coupling ect..... |
#6 | |
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
Kooks/Green cats are direct bolt up to all 3" Borla Cat backs. Once you install any new cat back you'll think the stock suitcase sounds like crap. That thing sounds like a tin can/empty beer cans compared to an aftermarket cat back. |
#7 | |
Can anyone else confirm fitment with corsa systems? I would prefer to go corsa, I find there systems to crackle more..... |
#8 | ||
I had the ATAK first, just sold that to Ron here (forum member). And i have a Borla Cat Back with S-type mufflers. ATAK was just to much on the street with valves open.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
#9 |
#10 |
I’ve got some from dash cam but really doesn’t pickup exhaust too well. I would need a go pro attached to the rear.
#11 |
#12 |
Ill get some flybys when its nice. re: the crackle, i have lots of it. Downshifts are snap crackle pop. Or simply letting off from high rpm.
#13 |
![]() ![]() ![]() ![]() Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
AWE is supposed to be a bolt up to all the major headers suppliers as well.
#14 | |
Truly appreciating the feedback guys! |
