Old 04-14-2021, 08:13 AM   #1
Lablkv6z
Lablkv6z's Avatar
Drives: 2000 Camaro SS, 1966 Mustang
Exclamation Brand new ported/modified LT2 intake manifold with MAP sensor pigtail
*SOLD*Up forsale is a brand new LT2 intake manifold ported and modified by me to fit LT1 engines. MAP sensor harness and stainless rear vacuum fitting included. I smoothed the intake runners and snout transitions. Did not remove much material from the TB opening on this one, for possible boosted applications.
This manifold swap alone has yielded 25+ whp. Will not fit under the stock hood of C7 Corvette’s. This will bolt right on 6 Gen Camaro SS’s with the stock LT1 fuel pump. The snout will fit your stock TB and retains the stock gasket. (Will need adapter to fit 95mm TB)*
Price is $575 shipped Paypal fees included in price. Thank you.
LT1 TB fits? Yes
LT1 bolts fit? Yes
LT1 orings fit? Yes
LT1 injectors and rail fits? Yes
I do have this on FB also.
Name:  bottom shaved.jpg
Name:  stainless fitting.jpg
Name:  MAP harness.jpg
https://www.youtube.com/channel/UCR-c7C5jMcEEQ4y_YaXMD6Q
LS3 Block (427CI)
Forged Manley 4.1" crank
T-Rod modded LS3 intake (by me)
Ported 821 heads (by me)
TSP cam 243/255 .621/.619 111 LSA
HP tuners pro (by me)
https://www.smokingasphalt.com/
https://www.youtube.com/channel/UCR-...cEEQ4y_YaXMD6Q
Lablkv6z is offline   Reply With Quote
Old 04-14-2021, 08:45 AM   #2
cheeze9878
cheeze9878's Avatar
Drives: 17 camaro ss
Does this fit with the LT4 fuel pump ( I think its a little taller the the LT1 fuel pump)?
cheeze9878 is offline   Reply With Quote
Old 04-14-2021, 09:02 AM   #3
Lablkv6z
Lablkv6z's Avatar
From what I've seen, it will bolt down but touch the LT4 fuel pump. To be safe, I would recommend a spacer if running the LT4 pump with this manifold.
That's why I stated that it will fit over the stock LT1 pump
LS3 Block (427CI)
Old 04-15-2021, 04:10 PM   #4
ThePeoplesCamaro
Patriot
ThePeoplesCamaro's Avatar
Drives: 2019 Camaro 1SS 1LE
Still available?
ThePeoplesCamaro is offline   Reply With Quote
Old 04-15-2021, 05:02 PM   #5
Lablkv6z
Lablkv6z's Avatar
Originally Posted by ThePeoplesCamaro View Post
Still available?
Yes it is still up forsale.
LS3 Block (427CI)
Old 04-16-2021, 09:33 PM   #6
Lablkv6z
Lablkv6z's Avatar
SOLD* thanks guys
LS3 Block (427CI)
lt2
