Old 04-13-2021, 03:06 PM   #1
Osbornsm
Drives: 2018 SS 1LE
Arrow Coolant boil off?
Okay i've done a few track days and i push it.
Q: Should i really have to add 2-3 quarts of coolant?
Thoughts?
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si
Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8
Results: 470 hp / 447 tq
Osbornsm is offline   Reply With Quote
Old 04-13-2021, 03:44 PM   #2
Z28GTOSSMike
Drives: 2019 Camaro 1SS
No. That's a lot of coolant to have to add under normal circumstances. Tracking it shouldn't make a difference.
Z28GTOSSMike is offline   Reply With Quote
Old 04-13-2021, 04:20 PM   #3
NeverDie
Drives: 2017 Camaro SS 1LE
I haven't added a drop of coolant in thousands of track miles in the Airzona heat.
I'd be pretty pissed off if I had to.
NeverDie is offline   Reply With Quote
Old 04-13-2021, 05:55 PM   #4
Desert1LE
Drives: Chevy Silverado, Camaro, Traverse
Nope
I havent added coolant in my 10 track days in Arizona and Nevada.
Desert1LE is offline   Reply With Quote
Old 04-13-2021, 06:05 PM   #5
funked1
funked1's Avatar
Drives: '23 Hyundai Kona N, '24 VW GTI
I've added maybe 8 ounces total in ~2 years.
funked1 is offline   Reply With Quote
Old 04-14-2021, 11:45 AM   #6
Trak-Toy
Trak-Toy's Avatar
Drives: 2023 SS 1LE
Not right at all. That’s over half gallon for a track day.. it’s leaking out somewhere. Internally or externally. What are the engine coolant temps and oil temps during the track sessions? What’s the oil look like? What’s the oil smell like? Burnt coolant? How much oil are you burning during these track events? Any smoke coming from the tailpipe? Even small amounts of coolant entering the combustion chamber will produce white exhaust smoke. I wouldn’t be driving the car until I got a better idea where this coolant is going. It won’t end well.
Trak-Toy is offline   Reply With Quote
Old 04-14-2021, 12:26 PM   #7
Osbornsm
Drives: 2018 SS 1LE
NO white smoke.
Oil smells and looks like used oil. No crazy foaming / mix action.
I have not had a measurable amount of Oil burn off from track days.
Well crap... that's not going to make me feel much better.
Any reason not to have the dealer diagnose this if i have headers??
Old 04-14-2021, 01:53 PM   #8
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Unless you're already OK with your powertrain warranty being toast and just need a competent shop to diagnose it, at least, a dealer sounds fine but I'd be more included to trust an independent shop.
Thats A LOT of fluid to not see white smoke, smell it, or have puddles under the car. Very strange.
Old 04-14-2021, 03:26 PM   #9
Baddawg53
Drives: 17 hyper blue 2SS M6
Mine uses some coolant, not the amount as yours though. But I've had to top it off a few times. It's not leaking, it's not burning it, it's not in the oil, it's a complete mystery to me. It never gets hot, even on a hundred degree day at the track.
Baddawg53 is offline   Reply With Quote
Old 04-14-2021, 03:39 PM   #10
funked1
funked1's Avatar
The lower reservoir vents to the atmosphere, so I think it just evaporates.
Old 04-14-2021, 04:19 PM   #11
weemus
Drives: 2017 1SS 1LE
I had to fill the lower reservoir. It was on the low side. I really can't say how full the lower reservoir was when I bought the car. Tracked all last year and never noticed. Checked this year pre-season and topped up the lower.
weemus is offline   Reply With Quote
Old 06-10-2021, 05:15 AM   #12
Jefe44
Drives: 2019 Chevy Camaro SS 1LE
Are you buying premixed? I saw a few videos from YouTube guys and they think it's ok to used bottled water instead of distilled. Distilled has a higher bubbling temperature than regular water. I don't know what my previous own used, but he was a car guy. I flushed and used distilled and have had no problems.
Jefe44 is offline   Reply With Quote
Old 06-21-2021, 01:24 PM   #13
5.M0NSTER
5.M0NSTER's Avatar
Drives: 2018 Camaro 1SS 1LE
Lower reservoir, I noticed mine looks empty. Upper reservoir is filled to the cold fill line, but I can't see any fluid in the reservoir directly underneath. I am not familiar with the 2 reservoir concept at all.
What's the purpose of the lower reservoir? Is it an expansion tank for when the motor gets nice and hot on the track? Should I put some coolant in?
I have a track day coming up on July 12th, and been driving hard just to get a better feel for the car. Coolant temps haven't gone over 200 yet.
5.M0NSTER is offline   Reply With Quote
Old 06-21-2021, 02:23 PM   #14
JK001
Drives: ZHP, Alfa 4C, RAM, X5, 17SS1LE-sold
Hmmm, if I remember correctly the top reservoir should show full hot or cold. The bottom should show half empty or so. That's how it was from factory, not sure how the two reservoir concept works
JK001 is offline   Reply With Quote
