Old 04-13-2021, 12:16 PM   #1
Darkside23
Drives: 2022 ZL1
800rwhp goals what is needed!
Looking at purchasing a zl1 but before I do I’m curious to what is needed to support 800rwhp with a A10 I’m new to the lt4 and need some insight, thanks in advance!
Darkside23 is offline   Reply With Quote
Old 04-13-2021, 01:01 PM   #2
IneedAZ
IneedAZ's Avatar
If you want reliability and not a lot of heat, then i would say Magnuson or Edelbrock 2650, Stage 2 cam, larger TB and intake, exhaust upgrade, Lower pulley swap, and good tune
Old 04-13-2021, 01:06 PM   #3
Darkside23
Drives: 2022 ZL1
How about the fuel system? What kind of power is the stock system good for?
Old 04-13-2021, 01:15 PM   #4
IneedAZ
IneedAZ's Avatar
DSX low side aux pump and Lingenfelter high flow check valve. Basically that is my build. Mine was 763 uncorrected and 801 corrected
Old 04-13-2021, 01:17 PM   #5
IneedAZ
IneedAZ's Avatar
If you dont mind trimming your hood then the edelbrock makes it easier to hook up secondary injectors. I didnt want to touch the hood and went Magnuson
Old 04-13-2021, 01:23 PM   #6
JSH
JSH's Avatar
Drives: '20 ZLE
800 wheel is 950 crank or bhp, which is the hp that KaTech, Lingenfelter, Hennessey and other prominent shops quote. Go to their sites and study the details of their builds. My mods in sig will make close to that hp. It takes a lot of work and a lot of money.
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 04-13-2021, 02:28 PM   #7
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
What IneedAZ said for sure!
It's not necessary but if port the heads you can probably squeeze out 30 hp more. Not that you need the extra hp but it can allow you to spin the blower slower to reach that 800 with less heat.
also do the 38% fuel lobe on the cam I see a lot of 32% being used seems like the fuel system is the week link might as well get the mostest lol
also if you plan on running 93 oct which should be fine for a 2650 at 800 to 850 I would use the cometic head gaskets that are tad thicker than the oem LT4s should bump the compression down just a tad if your gonna use meth, e85, or go for the record then don't worry about doing that but, you would be surprised it all adds up in the end.
Anything you can do stretch the limits 93 octane on a weak fuel system will be very beneficial! So Make the car efficient as hell.
Old 04-13-2021, 03:51 PM   #8
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
If you want to run this level of power on road courses you need to focus on keeping heat to stock levels or it will overheat for sure, and fueling should not exceed stock system beyond injectors, cam and voltage booster.
Adding a DSX aux pump will risk motor damage from G-force fuel starvation below 1/2 tank, and I wouldn't track my ZLE with that setup.
For street and drag racing only, this stuff doesn't really apply
SFV1LE is offline   Reply With Quote
Old 04-13-2021, 10:34 PM   #9
DOMIN8TR
DOMIN8TR's Avatar
Drives: 2020 ZL1 Exorcist
My Dyno chart from Hennessey has me at 824whp and 775ft-lb at the wheels for the Exorcist upgrade. Here’s what they did...
‘20 ZL1 Exorcist #52 Riverside Blue A10
DOMIN8TR is offline   Reply With Quote
Old 04-13-2021, 11:29 PM   #10
Schlok
Schlok's Avatar
Drives: 2015 Z/28 #397 2022 ZL1 #1799
Nice, glad you are enjoying your car. This isn't a bad thing that I'm saying but note that you have a 2.9L supercharger (Whipple I assume) vice most people go the Maggie 2650 route for this car.
Schlok is offline   Reply With Quote
Old 04-13-2021, 11:51 PM   #11
DOMIN8TR
DOMIN8TR's Avatar
The car is amazing and I’m loving every minute behind the wheel. It’s WAY more power than I need but I didn’t want any buyers remorse as I did with some of my other vehicles. It’s a Whipple SC and they offered me either one. I was told the lead time for the Whipple would be 4 weeks longer so I went with the Maggie because that’s what’s on my Tundra and I probably wouldn’t be able to tell difference anyway. When I took delivery and I popped the hood, I saw “Whipple” staring at me. I wasn’t mad but you bet your a$* I had a constructive conversation with them. At the end of the day they took care of me and it’s all in the past. I can’t wait to take it to Pocono Raceway to see what it can do!
Old 04-14-2021, 01:07 AM   #12
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
They usually list their dyno numbers in STD so it’s about 3% lower for SAE. Unless your dyno chart is in sae already but it’s probably STD.
Old 04-14-2021, 06:59 AM   #13
Markoz28
Drives: 18 ZL1 nightfall grey A10
Lots of big blower/cam Zs making 800-850whp SAE right now.
My car is ported stock blower/cam and made 780whp with Meth. I have since deleted the Meth and now tuned without it. No clue where I’m at but I’d guess 710-720whp
Markoz28 is offline   Reply With Quote
Old 04-14-2021, 07:26 AM   #14
JSH
JSH's Avatar
Drives: '20 ZLE
My HPE850 used the same component mods except my SC and TB were stock. As shown in my sig I'm going the Kong route currently. If I'm not happy with that hp level, I'll drop a higher volume SC (either the 2.9 or 2650) and high side DSX pump on it.
2020 ZL1LE A10.
