Old 04-13-2021, 10:22 AM   #1
Big Lebowski
Big Lebowski's Avatar
Drives: 022 C8 Z51 Red Mist HTC
Anyone replace / remove the rear diffuser?
Has anyone replaced / removed the rear diffuser on a Gen6 Camaro? I'm looking at replacing mine on my 2020 ZL1 as the previous owner scuffed it up pretty good on the underside.
Any good "how to" videos or threads? I've searched with limited to non-existent insight. Limited videos out there, and most suggest removing the entire bumper, which I'd rather not do. Here is the part as reference:
https://www.gmpartsstore.com/oem-par...cover-84306917
“Yeah, well, you know, that’s just like, your opinion, man.” - The Dude
Big Lebowski is offline   Reply With Quote
Old 04-13-2021, 11:16 AM   #2
Keloid
Drives: 2016 2SS
I swapped it on SS.
From what I remember, even though someone supposedly managed to do it without removing bumper (but on a V6), by the time I saw the number of clips in play... there was no way to do it on a car, at least I'd never attempt it.
Bumper comes off fairly easily with few tugs and since it's so elastic, there's little chance of messing it up.
Keloid is offline   Reply With Quote
Old 04-13-2021, 12:12 PM   #3
Hitman84
Hitman84's Avatar
Drives: 2022 Rapid Blue 2SS 1LE
Lethal Garage has a video of it.
https://youtu.be/vzqwd8X_6sw
Hitman84 is offline   Reply With Quote
Old 04-13-2021, 12:37 PM   #4
Big Lebowski
Originally Posted by Keloid View Post
I swapped it on SS.
Thanks guys. Ugh. What a PITA...after seeing videos like this, I'm confident I could do it, but it might be more than I want to tackle for the return. Cheers
Old 04-13-2021, 01:24 PM   #5
gotroost
gotroost's Avatar
Drives: 2021 Crush ZL1 1LE
For 19 and up (I think - mine is a 21), you do not need to remove the tail lights to removed the rear fascia. There are 2 electrical connectors on the driver side and one optical connector on the passenger side. The white tab pops open the optical connector.
I removed the entire fascia and it might be easier to just do that vs trying to remove just the diffuser while on your back.
Some of tabs above the license plate can be stubborn but I popped them off with a screw driver.
2021 Crush ZL1 1LE
gotroost is offline   Reply With Quote
Old 04-13-2021, 01:41 PM   #6
Boraz
Drives: Camaro LT1 A10 Blue
I second this. Removed the rear fascia to change my tail lights.
It was easy, took me maybe 45min. think its a 7 or 8 mm and a T15 bit.
Boraz is offline   Reply With Quote
Old 04-13-2021, 02:07 PM   #7
Big Lebowski
Gratefully, I have a 4 post lift. I just replaced the front splitter because the previous owner used it as a curb finder.
