![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Hot Red ZL1 Join Date: Nov 2010
M6 Shifter Shaking
I understand that some shaking is normal on these cars but could someone take a look at my videos and let me know if this is still consider normal? To me, it seems excessive. What do you guys think? Link to videos below. Video #2 shows how much movement there is.
https://youtube.com/shorts/z8JighTLb0o https://youtu.be/uLL_5MHOYg8
![]() Drives: Black 2019 ZL1 M6, Join Date: Sep 2019
seems to match the vibration of the road you are driving on. i hear your tires go over a bump and see it in the shifter. but i would defiantly get under and check the transmission cross-member or take it in for further exam. You dont want the tranny to drop out the bottom lol...
2019 Black ZL1, M6, CF Hood and Dash, Nav System, ZL1 Addons rock guards and lift points, Michelin Pilot Sport 4S, DD Smoked Marker Lights, Ceramic window tint, Gtechniq 9yr ceramic coating. JL Audio stealth box 12W6, Dyanamat trunk, Dead pedal cover, Soler TB/TC, Green Filter, Carbon-fiber Borla S-Type
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
Normal though it's more than other cars Ive had.
Thanks. That's what I think it just seems more excessive than what I have seen. I rather not take the car to a dealership unless totally necessary for warranty work. Anything I can do to make it less shaky?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
Seems excessive to me but it might be the road conditions causing some of the vibration. I really never noticed my shifter while driving. I drove mine to work today so when I’m driving home this evening I will check it out.
![]() Drives: Garnet Red / ZL1 1LE Join Date: Apr 2016
It's normal with this car.
#SAVETHEMANUALS
#7 |
![]() ![]() ![]() ![]() Drives: 2018 ZLE Join Date: Feb 2018
What was the road condition? If the road was very rough I would say thats normal but if you had a smooth road and thats happening I would consider it to be a issue. Mine moves relative to the road conditions.
#8 | |
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
My wife has something simillar that vibrates like that in her top dresser draw, let me ask her if its normal....
#9 |
![]() Drives: 2017 ZL1 Join Date: Apr 2020
Definitely not normal in my m6. I would check the tranny mount. Has the mount been replaced.
2017 ZL1 M6 Silver Ice Metallic
#10 |
Hot Camaro
If you're driving across cobblestone roads in PA, it's fine. If you're on a brand new length of buttery smooth pavement, it's not. Need more details to understand the total situation / context.
#11 |
![]() ![]() ![]() ![]() Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
I usually have my hand on my shifter most of the time, so I can't say for sure it shakes similarly. But with the vibrations felt in my hand, I would suspect it is the same.
#12 |
Hot Camaro
You should not rest your hand on the shifter while driving - it's bad for the internals of the transmission.
#13 | |
![]() ![]() ![]() ![]() ![]() Drives: 2023 CT5 Blackwing, 2025 C8 Z07 Join Date: Sep 2016
Normal for the ZLE. Just keep in mind you don't have a single rubber bushing in the car. That's what GM means by NVH.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 2025 Hysteria Purple C8 Z07 |
#14 |
