Old 04-12-2021, 02:14 AM   #1
Wuiquen
Wuiquen's Avatar
Drives: 2018 Hot Red ZL1
Coolant level question
I recently picked up a 2018 ZLE with 9k miles on it. I have been reading as much as possible about the coolant in these cars so I could educate myself. While shopping for the car, i saw a bunch with coolant expansion tank full and others totally empty.
This is what I understand so correct me if I am mistaken. The top tank is a expansion/return tank. This should be filled to bottom of the neck. The reservoir is at the bottom and this should be filled to the mark (i believe is like half way). Use the fill tube.
When I got the car, the coolant at the expansion tank was at at the bottom of the neck. Drove home and let the car rest. Next day i saw the expansion tank was like half full and the reservoir was filled past the fill mark. I washed the car so I needed to move it out of the garage, then went to check the coolant level and it was back to how it should be (expansion tank full and reservoir full to the mark).
Drove the car again and it is back to expansion tank half way and reservoir overfilled after the car rest for a day.
Can someone help me understand what is going on? Is this normal?
Old 04-12-2021, 02:37 AM   #2
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
The tank design is counterintuitive. The TOP tank is part of the loop and should always be completely full. If it's not, then you have air in your cooling system.
The bottom tank is the expansion tank, and should be HALF full.
It's a dumb design, but it is what it is.
Old 04-12-2021, 02:47 AM   #3
Wuiquen
Wuiquen's Avatar
Ok. Thank you for the explanation. So how do I get the air out? The coolant level had got to be right since the level at both tanks are right some times. It just seems that the fluid is moving around. Maybe someone filled the system improperly?
Old 04-12-2021, 03:04 AM   #4
Gunkk
Gunkk's Avatar
More likely it just evaporated and they never filled it (or thought it was normal).
The manual page I posted above explains how to fill it.
TL/DR: With car off and cold, open the cap & add coolant. Close the cap, start the car and run a minute. Rinse, repeat until no more air shows up in the tank. If it gets hot, the top tank will be under pressure so think of it as a traditional radiator cap.
Old 04-12-2021, 09:40 AM   #5
L78toLT1
L78toLT1's Avatar
For what it's worth, it appears that the coolant has been replaced in your car. The oem coolant is orange, in the pics yours looks to be red. This alone may not be entirely relevant, but it does indicate that the system has been opened up at some point.
Baby Blue
Old 04-12-2021, 09:56 AM   #6
Wuiquen
Wuiquen's Avatar
But... Given that the fluid has returned to proper levels at both tanks in the past, should I still fill it up? So if I refill the top tank right now, then the bottom tank would be overfill because it is past the fill line.
Old 04-12-2021, 10:19 AM   #7
Jaxcam02
Jaxcam02's Avatar
Drives: 2017 Silverado/2017 ZL1
I would fill, give it a week of observance for being at correct levels every time and fill if needed.
Jaxcam02 is offline   Reply With Quote
Old 04-12-2021, 11:37 AM   #8
Krowser
Krowser's Avatar
Drives: ZL1 Mosaic Black
I would refill the top tank to max capacity and observe for a week.
The top tank is not suppose to have that large open space.
Krowser is offline   Reply With Quote
Old 04-12-2021, 11:48 AM   #9
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
For reference, I have come across 3 6th Gens including mine where I was able to look under the hood. My SS, a V6, and a 2.0T all needed coolant. I even saved the premixed coolant and gave a lot of it to the V6 guy. The lower tank in his car was bone dry and the top tank was barely above the MIN line. Mine wasn't that bad but still needed sone,
Other way around. Factory fill is reddish-pink, you can only buy the orange stuff.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 04-12-2021, 12:05 PM   #10
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
I guess I’m lucky in that my 2017 isn’t really losing any coolant which I’m thankful. On past cars I have had problems like that and had to add coolant even if the system checked out okay.
Old 04-12-2021, 12:58 PM   #11
clg82
Drives: 2020 Camaro ZL1
subbed as i want to check my zl1 later today good info in here!
Old 04-12-2021, 11:12 PM   #12
Wuiquen
Wuiquen's Avatar
What do I do with the lower tank level? Right now it is past half tank meaning there is more fluid than it should have while cold.
Old 04-12-2021, 11:16 PM   #13
Wuiquen
Wuiquen's Avatar
What I am afraid of is overfilling the system. Like i said, there has been times or at least one time when I check that the level at the top and lower tanks were proper at full atthe top and half at the bottom
I would be ok filling the too if the lower tank was at the fill line or less but right now it is more than fill line so if I add more coolant to the top tank, wouldnt I be overfilling the system?
Old 04-13-2021, 12:05 AM   #14
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Only fill the top when cold. It should be at lowest level in top tank when its cold. Mine does weird crap too, bottom tank sometimes has less then half then when its fully warmed and running its back to half. I would only fill the top for now and just watch it. If the bottom tank is already around where it should be i wouldnt touch it.
Monitor it cold/hot for a few days.
