Old 04-11-2021, 09:42 PM   #1
Tigerflyboy
Drives: Chevy Camaro ZL1 1LE,AMG GTS, 94
Stock 1LE big loss of power
Hey Guys,
I've been lurking for a while so thanks ahead of time for the answers. I have 2018 ZL1 1LE with 5000 miles that I do HPDE events. Anyway I have lost a bunch of power for no reason. I went from doing 151mph at Roebling Road to now topping out at 135mpg. Same warm weather and same settings on PTM, ETC. It just feels like I have 150HP less!!! Today a Ford Mustang Shelby 350 was drafting behind me. Usually not even close. No codes, three tanks of gas from different locations and it runs/sounds fine. Going to a dealer tomorrow, but has anyone had the same problem?
Tigerflyboy is offline   Reply With Quote
Old 04-11-2021, 10:42 PM   #2
Vigilante375
Drives: 2018 Camaro ZL1
Maybe you have air in the supercharger coolant lines. Many of us have gone out and purchased a aftermarket solution for a supercharger coolant reservoir as that will make sure the line is always clear of any air.
You can go to the dealer and see if they can perform a bleed for the supercharger or do it yourself. As this will make the car feel sluggish with no codes or anything.
Old 04-11-2021, 10:48 PM   #3
Tigerflyboy
Hmmmm I'm new to the LT4 and that makes sense. The red reservoir on the passenger side was of the engine was almost empty recently. That was after sitting for 6 months.
Old 04-11-2021, 11:16 PM   #4
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
That is engine coolant not SC coolant. Intercooler is also a closed loop separate from engine coolant. Stock its a pain in the ass to bleed.
If you have the ability to log with hp tuners, you can check your IAT/MAT temps which would confirm if you have a heat soak type of issue.
Old 04-12-2021, 01:44 AM   #5
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Hey Guys,
#1 cause of loss of power: Air in the supercharger coolant loop. Even though it's a closed loop, water will slowly evaporate out over time.
There's no easy access tank to add fluid into, but there is a fitting. No need to visit the dealer if you are good with tools:
https://www.camaro6.com/forums/showp...8&postcount=12
If not, you can buy one of these for $15 and use a 2L bottle as a funnel:
https://dedicatedmotorsports.com/lt4...-adapter-tool/
Old 04-12-2021, 07:23 AM   #6
Jaxcam02
Jaxcam02's Avatar
Drives: 2017 Silverado/2017 ZL1
Or you can add a supercharger reservoir.
https://www.camaro6.com/forums/showthread.php?t=588728
Jaxcam02 is offline   Reply With Quote
Old 04-12-2021, 07:49 AM   #7
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
If you would rather have Black there is this option as well.
https://boostdistrict.com/products/s...SABEgL0MvD_BwE
Old 04-15-2021, 09:00 PM   #8
Wuiquen
Wuiquen's Avatar
Drives: 2018 Hot Red ZL1
If I use the aftermarket adapter and use the bottle as a funnel, how do I refill it? Do I just add coolant to the bottle and run the car until no more coolant goes in? How long do I run the car for?
Old 04-15-2021, 09:23 PM   #9
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
You can run the car, or do like I do and jump the intercooler pump circuit.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 04-15-2021, 09:47 PM   #10
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
it is definitely air in the intercooler circuit...get a reservoir ASAP
Old 04-15-2021, 10:40 PM   #11
Wuiquen
Wuiquen's Avatar
How would I jump the intercooler pump circuit?
Sent from my moto g(7) power using Tapatalk
