04-10-2021, 02:30 PM | #1 |
Drives: 2017 Chevy camaro 2ss Join Date: Jan 2021
2017 2ss camaro electrical problem need help solving
I have a 2017 camaro 2ss with an strange electrical issue it started 4months after purchase. So far the dealer has worked on the issue under factory warranty. Replacing the ECM and charging the battery, both worked as a patch but after a week to a month the problem would return. Bunch of codes thrown, dash would not read nothing but my fuel level every other gauge would not function, ABS light would come on, followed by stabilatrack service notification, parking break would not in gage or could not be disengaged.
All effects of the electrical issue starting but here’s where it gets strange my ss is manual so everything affected gets reset after I push the clutch in to change gears, every thing starts working normal then it goes away. I’ve let the manufacturer work on the vehicle up until now, they haven’t found the issue just patched it so I took my car to school to hooked an oscilloscope up hoping to find this interference, checked every module and fuse besides under the dash and nothing changed on the scoope still had interference. While the electrical issue is occurring if you turn the car off it won’t turn back on it, will ask you to push the clutch in to start, I had it to the floor and it didn’t read the clutch input so after 10 mins or a battery charger/jump box the vehicle will start. After start everything runs fine til it randomly wants to act up again. I’ve done 5things to this vehicle aftermarket head lights and taillights axle back delete kit and full zl1 1le aero kit and removed trunk padding and rear seats it was supposed to be a track car but can’t even make it a month on the road. My dealer is now saying my aftermarket taillights was the issue so I removed them, still the problem continues to be an nuisance. Now problem occurs on random so I installed my new headlights then rpm gauge flips out starts going crazy followed by every other electrical issue i do not know what to do at this point it’s been in and out of the dealer pretty much the whole year now they can’t guarantee warranty because of my taillights, service advisor says my taillights could have “potentially caused electrical damage” -_-. i need insight some sort of guidance to help narrow this down and fix it for good I love camaro’s, and this is my dream car I wanna be able to hit the track and feel that rush. Last edited by 2ss.kush; 04-12-2021 at 01:02 PM. |
04-10-2021, 03:21 PM | #2 |
Drives: 2016 Camaro 2SS Join Date: Nov 2016
Have you ever heard of periods?
Sent from my iPhone using Tapatalk |
04-10-2021, 04:51 PM | #3 |
so...you think his car was having its monthlies?
04-11-2021, 10:38 AM | #4 |
Drives: 2017 Camaro 2SS Join Date: Jul 2016
If I read this right (and that's a big if) it seems like this is your issue no?
-then I installed my new headlights rpm gauge flips out starts going crazy followed by every other electrical issue Stop installing shit til you get it straight
2017 2SS A8 TSP LT's, ported msd/95 mm, e85
04-11-2021, 06:38 PM | #5 |
Hot Camaro
04-12-2021, 11:00 AM | #6 |
Drives: Fast if no one's looking Join Date: Aug 2019
Holy run-on sentence Batman!
04-12-2021, 12:18 PM | #7 |
Sorry for the run on sentences
04-12-2021, 12:22 PM | #8 | |
The problem happened before anything was added and the dealer told me it was a bad battery but it wasn’t |
04-12-2021, 12:24 PM | #9 |
Hot Camaro
04-12-2021, 12:26 PM | #10 |
They charged the battery every thing was fine for 3 days then the issue came back. Went to autozone got a new battery and it patched the problem for a few days. So this time the problem would happen at random once you turn the car off and back on everything is good
