Old 04-09-2021, 04:38 PM   #1
getchapull
TEXIT
getchapull's Avatar
Drives: 2019 ZL1 M6
5w-40 oil in the ZL1
Thinking about switching to Royal Purple SAE 5W-40 High Performance Synthetic Motor Oil for my next oil change. They have a 0w-40 but it does not have the Synerlec additive. The 5W-40 does. They also have the HPS oil in 10w-40 with the zinc / phosphorus package.
Pros / cons?
https://royalpurpledirect.com/royal-...tic-motor-oil/
getchapull is offline   Reply With Quote
Old 04-09-2021, 04:50 PM   #2
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
I would use the weight the owners manual recommends just to be safe for your engine!
Old 04-09-2021, 04:55 PM   #3
ZX-10R
ZX-10R's Avatar
Drives: 2019 ZL1 Riverside
Royal Purple is probably the last synthetic I would pick
Castrol Edge, Amsoil, Mobil 1 EP (not th standard stuff) all fare well in standardized tests.
ZX-10R is offline   Reply With Quote
Old 04-09-2021, 05:54 PM   #4
EvilZL
EvilZL's Avatar
Drives: 2018 Camaro ZL1
This!
I just did an oil change for my 2018 ZL1 using the OEM recommended Mobil 1 Dexos 5W-30 with the AC Delco PF 64 Oil Filter and installed the Dimple Oil Drain Plug
EvilZL is offline   Reply With Quote
Old 04-09-2021, 05:57 PM   #5
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
This x 2.
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 04-09-2021, 08:12 PM   #6
Wuiquen
Wuiquen's Avatar
Drives: 2018 Hot Red ZL1
Originally Posted by EvilZL View Post
This!
Could you point me to which dimple plug you used?
Sent from my moto g(7) power using Tapatalk
Old 04-09-2021, 08:22 PM   #7
JSH
JSH's Avatar
Drives: '20 ZLE
Pros / cons?
Use the recommended/best: Mobil 1 ESP Full Synthetic 0W40
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 04-09-2021, 08:27 PM   #8
EvilZL
EvilZL's Avatar
Yes sir! I used the M12x1.75×21 Magnetic Drain Plug for GM
Recent models bottom of the page
https://drainplugmagnets.com/cars/gm-chevy-buick/
I just put my stock drain plug back in the Dimple container that it came in.
Old 04-09-2021, 08:34 PM   #9
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
agreed...Valvoline is also a good choice
Old 04-09-2021, 10:15 PM   #10
getchapull
TEXIT
getchapull's Avatar
Drives: 2019 ZL1 M6
This!
We have the same engine and the 5W hasn't grenaded your internals?
Old 04-09-2021, 10:21 PM   #11
EvilZL
EvilZL's Avatar
Na, just using the oem approved for my car. I don't track my car either.
It says right on my filler cap 5W-30 Dexos, so that's what I use
Old 04-10-2021, 03:06 AM   #12
swisstyphoon
Former GM Technician
swisstyphoon's Avatar
Drives: 2018 ZL1 A10, 06 Silverado Duramax
For competitive driving the 2017 and 2018 manual states to use 0W-40 or 5W-40. For 2019s and up models GM recommends 0W-40 in general for the LT4.
It is now also factory fill for LT4 Corvettes etc.
So why not use the better oil.
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can.
2006 Silverado Duramax Diesel
MPI Compound Turbo
40% over Injectors
Efi Live DSP5 Tuning
Follow me on Instagram: SwissZL1
swisstyphoon is offline   Reply With Quote
Old 04-10-2021, 04:38 AM   #13
EvilZL
EvilZL's Avatar
My owners manual says SAE 5W-30 and also has it on the filler cap, so that's what I use. There are plenty of oil threads on here, so to each their own.
Old 04-10-2021, 07:39 AM   #14
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
While I doubt any issues will come up with 5-weight, I believe GM did say they recommend the 0W over the 5W (excepting the ZLE) from earlier models, but it's just a sematic I think. 5W is just a little thicker in the cold, and I don't drive mine in the cold, so it doesn't matter too much to me. I'm more concerned with the Dexo 2 certification.
'20 ZL1 Black "Fury"
