![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 2SS A8 Join Date: May 2019
LT2 intake manifold - 90° fitting
Finally found an off the shelf 90° fitting for LT2 intake manifold. This is good if you don’t want your hose shooting towards the hood. Also will probably help to keep from hitting the insulation on the hood too. Barb is sized and should work fine for 3/8” hose. Bundy fitting is 10mm.
https://www.amazon.com/Dorman-800-17.../dp/B00CI6FBYE
![]() Drives: 2017 1ss 1le Join Date: Sep 2015
Thanks for this! It’s a big help!!!
No problem and you’re welcome.
