Old 04-08-2021, 07:21 AM   #1
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Torque Management Advance Issues
Hey,
I'm having issues where TqMgtAdv is pulling timing under heavy acceleration, especially after switching gears (M6). I turned TC/SC off (5+ second hold) and it will still happen. Any recommendations?
When it occurs I will see ~2 seconds where it holds off timing using TqMgtAdv and then snaps it all back in, really upsets balance of car.
Attached are two examples, one was PTM S2, other was everything off using 5 second hold
Old 04-08-2021, 10:13 AM   #2
NA18CamaroSS
NA18CamaroSS's Avatar
Drives: 2018 Chevrolet Camaro 2SS 1LE 6M
You can max out all of your torque tables to eliminate the issue. Just be prepared for wheel spin when you step on the throttle. Don't ask me how I know.
Bolt-ons.
NA18CamaroSS is offline   Reply With Quote
Old 04-08-2021, 11:47 AM   #3
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Nope, that's not how torque based tuning works. Yes, you can max the limiter but virtual torque and driver demand tables should not be just maxed out.
Old 04-08-2021, 01:09 PM   #4
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
There really isn't a whole lot of control for TqMgtAdv directly related to TCS options. What are my options, am I stuck doing stuff like changing my min timing from allowing negative timing in these areas to not allowing it?
Old 04-09-2021, 12:22 AM   #5
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
I think my actions are going to be the following after digging through some data
1) Inspect for Virtual Torque for being the limiting factor somtimes, found a couple cases where "Engine Torque" exceeded "Immediate Torque"
2) Found some cases where "Torque Management" / "Driver Demand" / "Increasing Predicted Normal/Tap" Delta torque values may be getting exceeded, will bump these tables up a little
Thoughts?
Old 04-09-2021, 10:00 AM   #6
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Mods?
Old 04-09-2021, 10:02 AM   #7
NA18CamaroSS
Torque
This is my tuner's solution. Attempt at your own risk. It works for me.
Bolt-ons.
Old 04-09-2021, 11:20 AM   #8
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Need to see Peak Tq table just to be complete.
Old 04-09-2021, 11:23 AM   #9
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Mods?
https://www.camaro6.com/forums/showthread.php?t=537171
This was the original setup, some minor changes here and there wheels, tires, toe bars, JMS FuelMax, etc.
Their tune seemed to avoid some of this issue by having the Min Spark high enough that you'd never allow negative tq based on TqMgtAdv. Trying to approach it differently by not setting TqMgtAdv in these cases. It also me trying to learn HP Tuners on GenV.
Old 04-09-2021, 11:54 AM   #10
KingLT1
KingLT1's Avatar
I don't think you can totally get around it without editing the minium spark table. If it was a torque limit issue then it would be closing the throttle blade. You could try adding 10% to the virtual torque tables. Highlight bottom row multiply by 1.1 then select entire map and interpolate selection then calculate coefficient. Rise repeat. However I believe there is some torque management tables that are not accessible and I believe it causes issues with M6 cars when in rev match mode. I haven't spent a lot of time on it since I haven't tuned any M6's but I don't notice the issue on my Brothers M7 C7Z. Wish I could be of more help.
Old 04-09-2021, 01:59 PM   #11
NA18CamaroSS
My tune vs stock peak torque table.
Bolt-ons.
Old 04-11-2021, 11:00 AM   #12
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Lot's of good progress. I doubled the "Torque Management" / "Driver Demand" / "Increasing Predicted Normal/Tap" Delta torque values. I didn't want to blindly slap them to the max like I see some folk doing.
I have eliminated almost all of my TqMgtAdv stepping in and crushing my timing by buffing up 25-150 lb/ft in different spots of my Virtual Torque Table. Now that I timing isn't dropping out I found a new area that I needed to touch up above 3800 RPM. Next time I go out I expect it to be all resolved or very close to it.
This apparently is valid method to stop TqMgtAdv from coming in and stealing all your timing
Old 04-08-2025, 11:26 AM   #13
J.A.Black
J.A.Black's Avatar
Drives: 22 Camaro 2SS 1LE
IDK if you're still around but I've been trying to figure this out for a while and this thread is the closest thing to what I've been experiencing. No one seems to know what I'm talking about when I describe the problem. It only occurs when I have Rev match enabled, but immediately after an up shift (manual car like yours) there's a severe delay in torque delivery, like my throttle won't open for the first second or 2, then it opens and I accelerate. From reading this thread it seems like this is what you're describing as well. Can you post exactly what you did to get around this? It sounds like you made some good progress but this last post implies there were more changes you were gonna try.
J.A.Black is offline   Reply With Quote
Old 04-09-2025, 08:02 PM   #14
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Sent you a PM on my process that solved everything
