Old 04-07-2021, 05:29 PM   #1
IneedAZ
IneedAZ's Avatar
Finally put my new wheels on
So, these are Weld Racing 17x 10 rears and 18x8 fronts. I went with Nitto G2 up front with R2 rears. I installed oem tpms sensors using the strap kit on all 4. I will not be leaving this setup on the car til I have worn out the tires on my oe wheels. At that point I will leave the new stuff on.
Ignore the fender tire gap as I just lowered the car back down and took pics so the springs need to settle again.
Old 04-07-2021, 05:50 PM   #2
Sickspeedkuwait
Sickspeedkuwait's Avatar
Drives: '17 ZL1 M6
Mean looking set up !
Sickspeedkuwait is offline   Reply With Quote
Old 04-07-2021, 05:50 PM   #3
MartinLe
MartinLe's Avatar
Drives: 2017 Chevrolet Camaro ZL1 M6
Badass Car! I am ordering the same rims for mine. I was waffling a little - until I saw yours. Thank you. What strap kit did you use for your sensors? Also, what size tires did you get? I'm thinking 245x50R18 Nitto Invo in the front and 305x45R17 Nitto R2's in the back. The only G2 I could find were 235x50R18 and they are 1/2" shorter than the rears. I can get the Invo with the same height as the rear.
MartinLe is offline   Reply With Quote
Old 04-07-2021, 05:58 PM   #4
Z OH 6
Drives: 2024 CT5-V Blackwing
Looks great for a drag setup. My favorite drag wheels at the moment.
Old 04-07-2021, 05:59 PM   #5
IneedAZ
IneedAZ's Avatar
The fronts are p245/45 and rears 305/45
Old 04-07-2021, 06:00 PM   #6
MartinLe
MartinLe's Avatar
Thanks. What strap kit did you use?
Old 04-07-2021, 06:07 PM   #7
IneedAZ
IneedAZ's Avatar
I got it from Amazon
Old 04-07-2021, 06:07 PM   #8
MartinLe
MartinLe's Avatar
The guy at Weld told me to keep the tires within 1/2" of each other in height. That more than that might upset the computer. Everything is working well, so far?
Old 04-07-2021, 06:10 PM   #9
IneedAZ
IneedAZ's Avatar
I tried to keep the tires close to stock diameter. I believe my fronts are almost exact. I also bought the oe tpms sensors from Amazon as they had the lowest price. I believe rears are 27.2 stock and these are 27.8
Old 04-07-2021, 06:36 PM   #10
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
Old 04-07-2021, 06:50 PM   #11
MartinLe
MartinLe's Avatar
Is this the TPM sensor you got? ACDelco 13598787 GM Original Equipment Tire Pressure Monitoring System (TPMS) Sensor Kit with Sensor and Stem
Old 04-07-2021, 07:12 PM   #12
IneedAZ
IneedAZ's Avatar
Yes
Old 04-07-2021, 07:18 PM   #13
MartinLe
MartinLe's Avatar
Cool. Thanks.
Old 04-07-2021, 07:22 PM   #14
IneedAZ
IneedAZ's Avatar
Just finished doing the tpms relearn.
