Old 04-04-2021, 10:18 PM   #1
Motor Fast
Drives: 2018 Camaro SS 1LE
Forward Collision Alert
It looks like on the ZL1 1LE's FCA is standard and they can't be ordered without this feature, unless you go with the PDR. Is this true? From what I can see in videos there's no way to disable it like can be done on the SS's, if the SS has the option. FCA is a deal breaker for me. It kind of sucks to pay $1,300 just to remove FCA. Thanks.
2002 Camaro SS | 2003 Corvette Z06 | 2008 Corvette | 2012 Corvette ZR1 Inferno Orange with PDE | 2016 Corvette Z06 C7.R | 2018 Yenko Camaro
Motor Fast is offline   Reply With Quote
Old 04-04-2021, 11:17 PM   #2
esm
esm's Avatar
Drives: 2019 ZL1
I disable it with a button on the steering wheel every time I get in the car. Not a big deal.
2019 Black ZL1 - A10
esm is offline   Reply With Quote
Old 04-04-2021, 11:26 PM   #3
Dirtytim
Drives: 2021 Satin Steel ZL1
You can turn it off pretty simply. There’s a button on the steering wheel. It also doesn’t really do anything other than flash a warning and make a beeping sound.
Dirtytim is offline   Reply With Quote
Old 04-04-2021, 11:26 PM   #4
Jofu
Drives: 2022 Wild Cherry ZL1 1LE
@esm when you disable it, does it leave an obnoxious message in the dash that says it’s disabled? It does that on my Impala, and it kind of sucks haha. For that reason alone, I was also considering ordering the PDR. That’s how much it annoys me
At least on the Impala, it’s happened many times where it jarringly applies the brakes when I knew exactly what I was doing, which can be pretty dangerous... Of course, I’m choosing to ignore the fact it probably does that because I’m driving a bit aggressively
Geoff
Jofu is offline   Reply With Quote
Old 04-04-2021, 11:39 PM   #5
2004YZFR1
Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE
Geoff
It doesn’t apply the breaks, just the flashing sign and the audible alert. Mine goes off when your not even close to a car sometimes.
Like it gets confused and sets it off.
2004YZFR1 is offline   Reply With Quote
Old 04-05-2021, 01:09 AM   #6
Jofu
Ah ok good to hear... applying the brakes from under you is just f’ed up and dangerous!!!
Geoff
Old 04-05-2021, 11:19 AM   #7
esm
esm's Avatar
Drives: 2019 ZL1
Geoff
No messages once turned off.
