View Poll Results: How long before your wideband sensor failed?
One week. 1 16.67%
One month. 0 0%
Two months. 1 16.67%
Six Months. 1 16.67%
One year. 0 0%
Longer than one year. 3 50.00%
Voters: 6. You may not vote on this poll
Old 04-03-2021, 12:55 AM   #1
NA18CamaroSS
NA18CamaroSS's Avatar
Drives: 2018 Chevrolet Camaro 2SS 1LE 6M
Angry AEM Wideband Failure
Quick poll: How long has your wideband sensor lasted before it failed?
My sensor failed approximately six weeks after install. It's still reading, but it's accuracy is toast. At idle when the car was in closed loop it would fluctuate between about 15.5 and 14.6. Now it's reading between 17:1 and 14.5:1 at idle. Going full throttle it's going as rich as 8:1. Ordered a new Bosch LSU 4.9 sensor for $35. I do get a ton of water in my exhaust when the car is cold, so I'm guessing that is what killed the sensor.
Bolt-ons.
NA18CamaroSS is offline   Reply With Quote
Old 04-04-2021, 01:06 AM   #2
Baddawg53
Drives: 17 hyper blue 2SS M6
There's not an option for it not failing so I picked over a year. Mines on over two years old and still going strong. At least 20k miles. Probably just jinxed myself here ...
Baddawg53 is offline   Reply With Quote
Old 04-04-2021, 08:20 AM   #3
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
How did you install the sensor? If it’s not clocked correctly (see attached) then you could get premature failure.
Old 04-04-2021, 10:35 AM   #4
NA18CamaroSS
AEM
The sensor is mounted in the left bung of the ARH X-Pipe.
Bolt-ons.
Old 04-04-2021, 10:59 AM   #5
Joshinator99
Moderator
Clocking position per the AEM instructions...?
Old 04-04-2021, 11:19 AM   #6
20Bluezl1
I had ARH weld an extra bung for the Wideband.
Old 04-04-2021, 11:43 AM   #7
NA18CamaroSS
It looks to be about 45*, so that seems like it's clocked "greater than 10*".
Bolt-ons.
Old 04-06-2021, 11:29 AM   #8
NA18CamaroSS
Confirmed. Replaced the sensor and the wideband now functions normally.
Bolt-ons.
Old 04-06-2021, 04:20 PM   #9
BruceWayne1LE
BruceWayne1LE's Avatar
Drives: 2018 Camaro SS 1LE M6
Does the sensor have to be in the collector or can it be in the catted connection pipes? Just had my headers coated and did not plan accordingly?
Camaro 2SS 1LE, MBRP Catback, Mishimoto Catch Can, Rotofab dry, TSP1 7/8” headers,DSX FF, Pray ported MSD, 95mm TB
492WHP 473WTQ
BruceWayne1LE is offline   Reply With Quote
Old 04-06-2021, 06:14 PM   #10
20Bluezl1
I believe it should be on the connector or at least before the cat.
Old 04-06-2021, 08:28 PM   #11
BruceWayne1LE
Yea it will be before the cat hopefully there is enough room on the connection pipes to do so. I’d love to not Jack up the coating
492WHP 473WTQ
Old 04-10-2021, 11:43 AM   #12
Texan4iu
BLEW BIU
Texan4iu's Avatar
Drives: 2018 2SS 1LE Hyper Blue
I am on my 5th or 6th sensor in a year's time. I've changed it twice in the last 3 weeks due to a failed sensor that originally worked for about 3 days, but then started bouncing around from 14-27, & then eventually the gauge read "Sens". My bung is at 9:00, so I'm guessing I need a new bung placed between 10:00 & 2:00 so it is angled per the instructions. I called AEM a few months ago when I initially hooked it up, but the gentleman I spoke to there said the angle does not matter, so that is why I never changed it. But I think it's time since I'm tired of changing it out.
Texan4iu is offline   Reply With Quote
Old 04-11-2021, 09:14 AM   #13
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
3years and no failure. Mine is welded in the cat delete pipe on driver side close to the factory o2.
My guess is those with repeated failures have the sensor to far back in the exhaust and they are not getting up to optimal temp... especially with headers.
Old 04-11-2021, 01:51 PM   #14
Texan4iu
BLEW BIU
Texan4iu's Avatar
I plan on moving mine right past where the headers end. Hopefully this will fix my issue.
