Old 03-31-2021, 06:30 PM   #1
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
Question: Tire aspect effect
Is there any major issue if your front tires have a 40 aspect ratio vs the rear tires having a 30 aspect ratio?
Reason: Looking to replace my rear wheels with 20x11 ET 43's with 305/30R20's
Thanks,
FlukeSS
Old 03-31-2021, 06:40 PM   #2
Getnlwr
Drives: '21 ZL1 A10 '08 SRT10
As long as you don't stray far from the overall diameter you shouldn't have an issue.
2021 ZL1 A10 in Satin Steel Metallic, 2008 Viper Vert M6 in Venom Red, 2018 ZL1 A10 in Bumblebee Yellow (SOLD)
Getnlwr is offline   Reply With Quote
Old 03-31-2021, 06:41 PM   #3
FlukeSS
FlukeSS's Avatar
Ty, I plan to do the 20x10 fronts as well just not right now.
I just wanted to make sure I didn't have anything major to worry about.
Old 03-31-2021, 08:09 PM   #4
Getnlwr
The computers algorithm for ABS and TC is likely something that will get messed up if the percentages are way out of whack. The only number the computer cares about is based on the overall diameter, or revolutions per mile (same thing). Hope it all works out.
Old 03-31-2021, 08:21 PM   #5
Homer2
Homer2's Avatar
Drives: 50th Anni.. coming home 11/01
just toss the sizes into a tire size calculator - and Bob's your uncle
Built Sept 16/2016 - #2681 of 5955. She came home with me 11/01/16. 50th Anni, 2SS, A8, NPP, NGM Rock Guards, Footwell Lighting, Black Bow Ties, Street Warrior Rotors and Pads, Ceramic Pro, 3M PPF, Oracle Ghosted Side Markers, Kooks 2" headers w/hi flow cats. GPI Stage 1 Cam installed at 305,000 kms.
Homer2 is offline   Reply With Quote
Old 03-31-2021, 08:31 PM   #6
Speedo will be 1.4% off and the look of the tires a bit strange (front sidewall remains 3.9" vs rear going from 3.8" to only 3.6"), but other than that, you'll be fine, nothing else should happen.
Old 04-01-2021, 04:04 PM   #7
chaospiece
Drives: 2018 SS, 2016 GT
You have to be within 2% difference in diameter of front and rear wheels or you will throw a stabilitrack code and go into limp mode.
If you're lucky enough not to always trigger limp mode, youll start to feel stabilitrack braking randomly trying to keep same rotation ratio. It's pretty annoying.
Went through it several times just trying out different sizes and manufacturers for fun.
chaospiece is offline   Reply With Quote
Old 04-02-2021, 10:29 AM   #8
ctrlz
Yes. This seems to be going around.
recent thread in the tire sub-forum:
https://www.camaro6.com/forums/showthread.php?t=589253
keep in mind, the car has no idea what size tires are on the wheels. You can slightly tweak the effective tire diameter using tire pressure. So if your tire choice is on the edge of throwing a code, you might be able to run +2 psi up front and -2 psi in back or vice-versa.
Old 04-02-2021, 10:36 AM   #9
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
Thanks,
FlukeSS
I depends. The apect ratio is the tire sidewall height as a percentage of the tire width.
So two tires with 30 aspect ratio can have completely different sidewall heights if the tires widths are very different.
Main thing is to try to keep the tire diameter as close to stock as possible.
Spaceme1117 is offline   Reply With Quote
Old 04-02-2021, 12:21 PM   #10
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
Thanks,
FlukeSS
Your car should have come with 245/40-20 front tires and 275/35-20 rear tires.
I'm pretty sure that your rear wheels are no wider than 9.5", which is a whole inch narrower than any 305/30-20 tire should ever be squeezed onto. If you want 305-wide tires, get wheels that are 10.5" or 11" wide.
Norm
Old 04-02-2021, 12:49 PM   #11
Fraxum
Fraxum's Avatar
OP if you want your speedo to be correct without tuning then make sure the tire is right around 27.5" high. And this is really important in the front where if you go taller you will most likely need spacers. Been there done that.
If you do go with a taller tire the difference between the front and back cannot be more than an inch, otherwise stabilitrac will get very upset.
Old 04-02-2021, 01:58 PM   #12
delthawk5
Drives: 2019 2SS Crush
Personally wouldn't **** with it.
2019 2SS Crush Orange - NPP
2016 BMW 4 Series Gran Coupe | 2013 Genesis 3.8 R-Spec | 2012 Scion FR-S
delthawk5 is offline   Reply With Quote
Old 04-03-2021, 10:54 AM   #13
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
I don’t understand why people don’t use the TireSize.com website to check and see what sizes of tires are compatible with the stock sizes. It lets you compare different sizes and tells how much the speedometer will be off. They cover different size wheels too. I used the website when I had my 2016 2SS and was looking at going to a different size rear tire on the stock wheels. I had 285/35s installed and didn’t have any issues. Good luck to the Op.
Old 04-03-2021, 02:10 PM   #14
Norm Peterson
Not everybody brings a numbers-oriented mindset to the matter of choosing tires. Isolated scraps of understanding at best, nothing about how they all fit together.
No flame intended, that's just the way it's been pretty much forever.
Norm
