Old 03-23-2021, 12:29 PM   #1
SCSpeed
Drives: 18 ZL1 1LE
Rear Camera/Cooled Seats/Heated Seats Not working
2017 ZL1
I just got he car back from bolts mods last week:
Headers
Lower Pulley
Everything was good the first couple days then yesterday jumped in the rear camera screen is blue and service camera message appears. At the same time the heated and cooled seats have stopped working, when you hit the buttons none of the orange lights turn on and the seats do no do anything.
I checked on the fuses per the manual in the engine compartment and trunk, I disconnected the battery to reset the BCM.
I messaged the tuner he has no ideas of the cause or a solution.
Anyone have an insight?
SCSpeed is offline   Reply With Quote
Old 03-23-2021, 12:44 PM   #2
boosedep3
Drives: 2018 SS1LE
Have you checked the harness? Is it possible the headers could have cooked the wires?
boosedep3 is offline   Reply With Quote
Old 03-23-2021, 01:55 PM   #3
ZLE dude
Drives: '18 ZL1 1LE
This would be my first thought as well. Look at the wiring harness that runs along the body inside the engine bay under the coolant reservoir on the passenger side. It runs VERY close to the headers. I wrapped my in heat shield and zip tied it back about 2" from where it normally lays to try and give it some breathing room from the headers. This is looking straight down where the coolant reservoir would be sitting.
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
ZLE dude is offline   Reply With Quote
Old 03-23-2021, 02:10 PM   #4
SCSpeed
Drives: 18 ZL1 1LE
Appreciate that I will check it ASAP!
Old 03-23-2021, 02:20 PM   #5
ZLE dude
Drives: '18 ZL1 1LE
Sounds good. I hope I'm wrong.
Old 03-23-2021, 05:00 PM   #6
PROMETHEUS
PROMETHEUS's Avatar
+1, most likely melted a wiring harness. Too many things went wrong at the same time for it to be anything else, IMHO!
