Morning,
I cannot for the life of me verify the part number for the SS 1LE front brake caliper bolt. ![]() This is the 6-piston Brembo setup. -------------------------------------------------------------- Part number: __________ ??
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8 Results: 470 hp / 447 tq |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 2SS M6 Join Date: Jun 2013
front #11611085
rear#11570091 they are the same on all SS, SS/1LE, ZL1, ZL1/1LE
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS/RS Join Date: Dec 2009
Here’s another option from Screaming Chicken.
There non-TTY bolt an it’s a complete set. https://screamingchicken.com/2016-21...caliper-bolts/
Orange Krush II
#4 | |
No way really? I just ordered these: 11570092 I'm not sure what i just purchased then.
same part just updated part number looks like. Few $ cheaper too.
#6 | |
![]() Drives: 2018 1SS Join Date: Dec 2018
Are the brake caliper bolts TTY on these cars?? I did not think those were.
2018 Red Hot 1SS, GM lowering kit & 1LE Sway bar kit, ZL1 1LE solid rear cradle bushings, BMR sway bar end links, GM CAI w/tune, Pray ported IM, Mamo ported TB, VS Forged VS07 rims 20x11 & 20x10 w/ Michelin PS4S
#7 | |
Yes they are, as are alignment bolts too. *sigh
#8 |
Brake caliper bolts ARE NOT one time use TTY. They are TTA or TA. Which means torque + angle. They can be cleaned and reused with Loctite per the service manual. I've done it many times.
First Pass: 150 N-m (111 lb ft) Final Pass: 15-30 degrees |
#9 |
I love that I got two opposite answers to that question. I was at my local dealership this past weekend and they said that they reuse the caliper bolts as well. Not that that means much - not all dealership techs are superstars, but I would think they know the basics.
#10 |
[QUOTE=Shawnqa800720;11007602]I love that I got two opposite answers to that question. I was at my local dealership this past weekend and they said that they reuse the caliper bolts as well. Not that that means much - not all dealership techs are superstars, but I would think they know the basics.[/QUOTE
Easy enough to access the service manuals and get your own answers like I do. www.repairprocedures.com |
#11 | |
[QUOTE=carguy55;11007774]
Would be great if it were free, but needing to subscribe seems crazy in this age of information. Are there free options - open access to service manuals? I thought that was passed as legislation, but maybe that was just local...
#12 |
[QUOTE=Shawnqa800720;11010122]I use the $15 for 1 day option and print to PDF everything I need
#13 | |
![]() ![]() ![]() Drives: 2017 1SS 1LE Join Date: Jun 2016
2017 SS 1LE.
#14 |
BLEW BIU
Drives: 2018 2SS 1LE Hyper Blue Join Date: Oct 2017
