Old 03-22-2021, 09:33 PM   #1
BanOne
Drives: 1977 Pontiac Trans Am
Newbie Trailering Questions
So going to start doing track events and in the process of getting ready I had planned on leaving the car in gear and use the ebrake while trailering. But one of my friends suggested leaving the car in neutral not wanting to allow the transmission to take any of the brunt. I have trailered several cars before but once I thought of it they all were autos and by default it rested on the transmission and the ebrake. My question is what config do you guys trailer in manual transmission in gear or not, ebrake on or not?
Thanks in advance
Doug
BanOne is offline   Reply With Quote
Old 03-22-2021, 09:46 PM   #2
ember1205
Hot Camaro
ember1205's Avatar
Thanks in advance
Doug
My M6 was trailered home from the dealership by me, about 140 miles. Once loaded, I strapped the front wheels down with the basket straps, car was in gear, e-brake set, and off I went. Not sure why you wouldn't trust the beefy Tremec as much as the A8/A10...
Old 03-22-2021, 10:08 PM   #3
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
I just use the park brake. If you have that set, it doesn't matter if the trans is in gear or not. It'll slide before the park brake lets a wheel turn enough to load the trans.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 03-22-2021, 10:12 PM   #4
joelster
joelster's Avatar
Drives: '94 Z28+ '15 Z/28
Always put it in gear. Pull the ebrake and strap in down.
1973 Mach 1, 351C cruiser
'15 Z/28 Red Hot, A/C
1980 Z28- resto-mod project
1979 Y84 Trans Am
1986 IROC-Z
joelster is offline   Reply With Quote
Old 03-22-2021, 10:18 PM   #5
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
correct sequence is strap down tight in neutral, set e brake, and then put in gear last.
Old 03-23-2021, 07:34 PM   #6
BanOne
Thanks for all the input
Old 03-24-2021, 07:40 AM   #7
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
Stephen is spot on.. Even says this in my Furtua manual
Timbo-1LE is offline   Reply With Quote
Old 04-29-2021, 08:56 PM   #8
Jjmongelli@aol.com
Johnny Z
Jjmongelli@aol.com's Avatar
Drives: Chevrolet ZL1 Camaro 1LE
E-brake and in gear
I always put in park with E brake on then strap down !
Jjmongelli@aol.com is offline   Reply With Quote
Old 04-29-2021, 09:17 PM   #9
Scargoes
Scargoes's Avatar
Drives: '18 Hyper Blue 2SS1LE '20 Crush RSR
There is a big difference between an Auto and a Manual when in park vs a gear. When in park in a auto, there is a park pawl that locks the transmission. It isn't using gears to hold anything. It is a metal pin holding the transmission from moving.
As for towing, I pull my car on the trailer to the parking stop I have and set the parking brake. Leave it in neutral. Then strap down over the tires.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:28.95 Willow Springs Big Track
Scargoes is offline   Reply With Quote
Old 04-29-2021, 11:08 PM   #10
evanescent03
evanescent03's Avatar
Drives: '19 SS 1LE/'19 Rubicon/'20 AT4
guess i'll start doing this, seems to make sense! did 2,500 miles this past weekend and thing didn't budge using E-track and Mack's Straps despite strapping last. always in for "best practices" though!
evanescent03 is offline   Reply With Quote
