Old 03-21-2021, 11:21 PM   #1
slowwhite711
Drives: 2017 1lt Camaro V6
2018 Camaro ZL1 running sluggish?
Hey guys new to the forums here and I am in need of some help. Just picked up a 2018 Camaro ZL1 and the dealership filled the gas up with 87 gas. Car has been running sluggish and I made sure not to drive crazy on this gas till it was empty. Now that the car was empty I filled it up with 91 and have been driving around with it but the car still seems to be under performing and running bad, to the point I even got a few runs with some friends and they all legit gave me a beating where as my 2019 E85/header 10r80 mustang would beat them by a car length. I am going for my second 91 fill up tomorrow so I’m hoping this will help but I’m not sure what else to do.
slowwhite711 is offline   Reply With Quote
Old 03-22-2021, 01:51 AM   #2
gtfoxy
Drives: '21 Wild Cherry ZL1
First off congrats on the ZL1.
As for performance wise it sucks the dealer did that. I personally would have made them drain all the fuel & put high octane in before I took delivery, but that’s just me.
How many miles on the car?
Mods?
Any maintenance records?
Make sure the exhaust setting (via the infotainment system) is set to track as well as your main performance selector. You should also make sure your PTM settings are not on wet, but dry or Sport 1 or 2 is a good all around setting. Race mode will require you to be more regulative of the throttle, but not as bad as turning TCS off completely. I personally have mine set to Sport 2 99% of the time.
91 is really the bare minimum, but that’s what I personally have ready access to, so I understand.
Do you have any way of monitoring or logging data? If not at a minimum download the Torque Pro app & get an approved ElmScan interface & monitor RPM, knock retard, Manifold temp, manifold pressure, MAF. That will give you a pretty good idea of what’s happening.
I would also recommend making sure the blower coolant circuit is properly bled. Air in the circuit will cause a pretty drastic drop in power.
Old 03-22-2021, 08:13 AM   #3
d15b7
d15b7's Avatar
Drives: 2020 Camaro ZL1 1 LE
hey there and welcome! everything GTfoxy said is pretty spot on. I'll add that I guess I'm lucky in that 93 is the 'normal' Premium grade fuel that we get here in the northeast so that's what I use (I prefer Shell). mine is stock and I can say that 'sluggish' is in no way a descriptor that I'd use in reference to when you press the go pedal; it's insanely fast!
running the 87 oct would have most likely not have hurt it assuming you weren't romping on it; but I'm sure it would have radically retarded the ignition timing trying to protect the engine from knocking. i'm assuming you ran it totally down to complete empty and then filled up with a full tank of 91? if you mixed the 87 and 91 you're still going to be way low on octane and it might still be really retarded. can you go to a VP racing distributor and buy 5 gals of GT260 100 octane unleaded and toss it in there and go for an extended drive? see if it 'relearns' and gets back to running the way it should, which I like to describe as 'crazy fast'. good luck and enjoy her!
d15b7 is offline   Reply With Quote
Old 03-22-2021, 08:32 AM   #4
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
Did you drive the car prior to the 87 octane? If so, how did it run?
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
zx9rmal is offline   Reply With Quote
Old 03-22-2021, 09:08 AM   #5
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Congratulations and maybe it will straighten out with another tank of 91. I would also put a bottle of injection cleaner in the tank when you fill up. Btw, your Mustang was not as heavy as your Camaro which would make it faster especially since it was modded. If you keep having problems with it, I would find a good dealership to take it to get checked out if it is stock with no mods done.
Old 03-22-2021, 09:26 AM   #6
19Nasty1le
Craig
19Nasty1le's Avatar
Drives: 2019 ZL1 1LE
Your computer is going to take time making sure the octane levels are correct before returning the timing to normal levels, it might take a tank of high grade gas to even get there, if by the end of a 2nd tank of high octane gas (with some more aggressive driving to see if it picks up) I’d return to the dealer as maybe the issue is also the vacuum that some cars have had with the supercharges
19Nasty1le is offline   Reply With Quote
