Old 03-21-2021, 06:45 AM   #1
Purplt1
Purplt1's Avatar
Drives: 2020 ss
Which intake manifold?
Looking for more power
My current set up is
20 camaro a10
Tune
Tsp stock casting ported heads
Tsp vvt2 cam
1 7/8 headers
Ported lt2
95mm tb.
I have been looking at high ram intake but was just wondering if I should stay with the lt2 or would it be a noticeable difference with high ram? I would like to keep the 95mm throttle body. if I should get a holley should I get the 92mm version?
2020 Camaro SS
Heads,cam,hi-ram,hhp tcm
Purplt1 is offline   Reply With Quote
Old 03-21-2021, 09:01 AM   #2
LT1ornothing
Drives: 2020 LT1 M6
20 camaro a10
Tune
Tsp vvt2 cam
1 7/8 headers
Ported lt2
95mm tb.
Are you ready to cut your factory hood or purchase an Anderson composites hood to go with your high ram? Because that's the only way a high ram will fit...
Old 03-21-2021, 09:02 AM   #3
6spdhyperblue
Drives: 2SS 1LE
On a cammed car you gotta go high ram or msd. So yeah.
Old 03-21-2021, 10:40 AM   #4
Puddin
If I was you I'd look at a msd instead of a High Ram since your on the smaller side of cams.
Old 03-21-2021, 01:37 PM   #5
Purplt1
Purplt1's Avatar
Drives: 2020 ss
Yes.dont mind cutting it up.
2020 Camaro SS
Old 03-21-2021, 01:39 PM   #6
Purplt1
Purplt1's Avatar
Drives: 2020 ss
Thats another intake I was thinking about. Just looking to squeeze some more power out of my set up and didn't know if the high ram would hurt my set up.
2020 Camaro SS
Old 03-21-2021, 01:50 PM   #7
NA18CamaroSS
NA18CamaroSS's Avatar
Drives: 2018 Chevrolet Camaro 2SS 1LE 6M
Probably MSD with your current set up. If you go bigger on your cam, high ram.
Bolt-ons.
NA18CamaroSS is offline   Reply With Quote
Old 03-21-2021, 02:41 PM   #8
Puddin
With the High Ram it likes big cams and high rpm so the MSD will be a better fit for you since you're probably not turning over 7K rpm. You'll definitely pick up some more power over the LT2 and carry it further with the MSD.
Old 03-22-2021, 11:57 AM   #9
SilverSurfer18
SilverSurfer18's Avatar
Drives: 2021 1SS Camaro
Way off topic here but how is the drivability with that cam since you cannot tune your trans or put in a higher stall TC or anything? I have a 21 A10 and am looking at cams myself..
2021 Wild Cherry 1SS, LT2 Intake, Rotofab, Borla S-Type, Texas Speed longtubes, SMG flex fuel sensor, GPI Tuning, Bronze 1LE replicas
SilverSurfer18 is offline   Reply With Quote
Old 03-23-2021, 07:04 PM   #10
Purplt1
Purplt1's Avatar
Drives: 2020 ss
Driviabilty is basically like stock, I actually daily this car. I'm sure the performance would be a little better with some trans tuning. Overall I'm very happy with my set up but always looking for more power.
2020 Camaro SS
Old 03-23-2021, 09:30 PM   #11
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
What the purpose of your build that should determine what intake you need an will work best.
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components.
olblue75 is offline   Reply With Quote
Old 03-24-2021, 06:16 AM   #12
Puddin
For full bolt ons the Lt2 or Lt1 ported is better suited. When you step up to heads cam that's when you move to an MSD or depending on cam size and how tricked out your heads are you move to the High Ram. Stroker motors also play a role because they want more air so you got to have the right manifold to feed it.
Old 03-24-2021, 06:53 AM   #13
s346k
s346k's Avatar
Drives: like an old lady
i have a ported msd on my bolt on car. night and day difference in performance on the street. no loss in tq but a lot out of rpm gained and decent hp.
Old 03-24-2021, 07:14 AM   #14
Puddin
Yea some people with bolt on cars use the MSD but they also usually have aspirations to move on to a heads cam setup so they buy it while they can because it's just another piece of the puzzle.
