Old 03-19-2021, 10:48 PM   #1
PeteSS2018
Drives: 2018 2SS Camaro
Major misfire issues ... help!
Yesterday I was driving and went around a big long left hand loop ... a freeway to freeway connection. I was going about 50mph, not going too hard but this piece of road is like 3/4 of a circle. I was at constant speed and fairly low revs although cornering tightly but nowhere near the car's limit, not even close. As I exit the bend and head up the hill that it goes into accelerating fairly mildly up to 60mph, my oil pressure gauge jumps UP, and in 8th gear I get a major shudder like a bad misfire. While it did accelerate, it was very lacking in power, and also my CEL and Stabilitrak lights came on, the CEL flashing at times and steady at others.
I found the nearest place to get off the freeway, parked & stopped and let the car cool for maybe 20mins. Tried restarting it and it had a seriously rough idle, like several cylinders are down. It also backfired on start up once and sounded very unwell. Being where I was I had no option but to limp home, at slow and steady speed, but it was rough and misfiring with any amount of throttle. Flashing CEL a lot of the time, sometimes back to steady CEL. Also the Stabilitrak dash light coming on most of the time.
The whole time the oil pressure was up higher at idle than usual (by a quarter of the gauge) and jumped up rapidly under revs.
So yeah, high oil pressure - has never happened before - and very rough/misfiring.
I'm thinking a stuck oil pressure relief valve causing lifter issues. But thats just a guess. Am going to get a truck and send the car over to a mechanic Monday and hopefully get it fixed without too much pain and expense.
Anyone want to take a guess where to start with what it is???? Any help appreciated.
2018 2SS, Hyper Blue, Australian HSV delivered
2.9L Whipple 98RON tuned 650hp/850Nm
Elite Engineering E2 Catch Can
Eibach Prokit springs
Mamo LT1 Ported TB
PeteSS2018 is offline   Reply With Quote
Old 03-20-2021, 12:55 AM   #2
Puddin
Maybe a valve spring failure.
Old 03-20-2021, 01:49 AM   #3
PeteSS2018
I wondered that with the missfire, but high oil pressure?
Mamo LT1 Ported TB
Old 03-20-2021, 12:20 PM   #4
Trochoidal
Drives: 2017 Camaro 2SS A8
This is a rather odd problem mentioned in this thread with similar symptoms minus the high oil pressure.
https://www.camaro6.com/forums/showthread.php?p=9983174
Old 03-12-2025, 09:13 AM   #5
farshad525hou
Drives: 2023 Camaro 2SS
Follow up
Just really curious what ended up being the issue here? Same thing literally just happened to my 2023 2SS last night. Down 1 more multiple cylinders misfiring bad - ESC service light. Im suspecting but hoping its not a broken valve spring. Shes sitting at the dealership now waiting to get diagnosed.
farshad525hou is offline   Reply With Quote
