Old 03-19-2021, 01:14 PM   #1
clg82
Drives: 2020 Camaro ZL1
Mild 2 wild work on 2020?
Hey everyone does anyone know if the mild to wild switch works on the 2020 ZL1? On the website it stops at year 2018. Thanks for any help.
Old 03-19-2021, 06:33 PM   #2
clg82
Anyone lol?
Old 03-19-2021, 06:49 PM   #3
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
what the hell is a mild 2 wild switch? lol
Old 03-19-2021, 07:03 PM   #4
clg82
It's something you can use on cars with NPP to keep the valves open if you want or go back to stock settings......if you want to drive around with the valves fully open you can by the push of a button!
Old 03-19-2021, 10:53 PM   #5
puppykat33
puppykat33's Avatar
Drives: Black 2019 ZL1 M6,
its called track mode in you settings for the car. it already has a switch. no need for another one.
2019 Black ZL1, M6, CF Hood and Dash, Nav System, ZL1 Addons rock guards and lift points, Michelin Pilot Sport 4S, DD Smoked Marker Lights, Ceramic window tint, Gtechniq 9yr ceramic coating. JL Audio stealth box 12W6, Dyanamat trunk, Dead pedal cover, Soler TB/TC, Green Filter, Carbon-fiber Borla S-Type
puppykat33 is offline   Reply With Quote
Old 03-19-2021, 11:24 PM   #6
SoCal Smith
SoCal Smith's Avatar
Drives: 2019 Camaro ZL1 1LE A10
no, just pull the fuse!
SoCal Smith is offline   Reply With Quote
Old 03-20-2021, 12:16 AM   #7
jvandy50
Drives: 18 ZL1-1LE, 10 JKU
This is what I did. Kept noticing it would close valves even in track mode at times. Just no GM
jvandy50 is offline   Reply With Quote
Old 03-20-2021, 01:36 AM   #8
Getnlwr
Drives: '21 ZL1 A10 '08 SRT10
I'm guessing you pulled the wrong fuse then... It's #51.
I did it to try it and the valves were open the entire time. I just got tired of hearing it and put the fuse back in eventually. The Rhaspy sound of our cars doesn't do it for me.
Getnlwr is offline   Reply With Quote
Old 03-20-2021, 07:28 AM   #9
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Originally Posted by clg82 View Post
Anyone lol?
cig, my suggestion is to email the company that makes the switch and ask them if you are really interested in adding one to your ZL1. The replies are correct though and that’s what people do. I pulled the fuse out in my ZL1 and really didn’t notice too much of a difference in sound so I put it back in and set the exhaust mode to Track!
Old 03-20-2021, 08:45 AM   #10
Hambo864
Drives: Chevrolet Camaro SS 1LE
https://www.rpidesigns.com/shop/item...EaAmo_EALw_wcB
Mine arrives today. You can use the coupon "Save" and it saves like 5 bucks. Make sure you select the ZL1 option. I too wanted to have control of how and when the valves closed without pulling the fuse. I installed a Corsa NPP and when the valves close on it, its like hitting the mute button. Very very obvious that they closed. Its a shame there isn't a way to adjust the valves in HPTuners.
Hambo864 is offline   Reply With Quote
Old 03-20-2021, 11:04 AM   #11
clg82
it stops at model year 2019, I was asking if anyone here had any knowledge of it still working with model year 2020
Old 03-20-2021, 12:15 PM   #12
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
You can change what the valves do in every mode, any rpm in hp tuners.
Old 03-20-2021, 06:29 PM   #13
sengli
sengli's Avatar
Drives: 2015commemorative vert 2SS
I had the m2w system on my C6 and it worked great. Tried it on my Gen5 camaro and it was a dud. The stock NPP is way more responsive, so the M2W system is in a junk box on the shelf.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded
2015 commemorative vert 2ss
sengli is offline   Reply With Quote
Old 03-20-2021, 08:54 PM   #14
Dan82679
Dan82679's Avatar
Drives: 2017 ZL1
I have mild2wild and it's great. One quick push of a button
on my key chain and valves open or close. I don't have mess with the touchscreen and flaps stay open no matter what rpm. Also for a quiet start up I hold the start button for 10 seconds until accessories turn on push the button to close the valves and start the car nice and quiet.
Dan82679 is offline   Reply With Quote
