Old 03-17-2021, 10:31 AM   #1
ud03803
ud03803's Avatar
Drives: 2018 Camaro 1SS Blue
Stock SS Driveshaft
Hey guys, just want some input from people running drag radials in an auto with stock driveshaft. I saw one thread where a guy had a problem but have not found much other info. I do plan to put a loop on it just in case. My car is fbo, h/c, e85. I have a 150 shot if I am feeling confident about it but wouldn't spray it until 2nd gear. Just looking for some feedback from anyone still using a stock shaft at the 540whp+ NA level.
CNC Ported 12:1 Heads/Kooks 1 7/8"/Hellion custom cam/Atomic MSD/Tony Mamo V2 PTB/K&N CAI/E85/All LT4 Fueling/Mystery Axle-back/Gap Juice
ud03803 is offline   Reply With Quote
Old 04-24-2021, 04:58 PM   #2
6spdhyperblue
Drives: 2SS 1LE
Look at finding a m6 zl1 driveshaft
Old 04-24-2021, 05:56 PM   #3
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Destroyed my SS driveshaft back a couple of years ago when I was probably in the 630-650 WHP range. Definitely get yourself the safety loop no matter what! I went with the GForce 3.5” aluminum shaft but the DSS and QA1 shafts are great also.
Old 07-14-2021, 05:23 PM   #4
oldman
Drives: SS 6 speed of course
Got my ZL1 M6 driveshaft (don't know if the auto fits too??) and it was a direct bolt on to my SS M6. Posted pictures a while back. Cost was like $125 including shipping. Pretty sure 1 side if not both sides of the Zl1 halfshafts work too.
Old 07-23-2021, 09:12 PM   #5
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
My 90k H/C/I SS has been going fine on the stock driveshaft. With the way people talk about it and the stories you would think they would blow up immediately.
Although it does make the car sound and feel like a POS especially with the carrier/center support slop and noise when shifting from drive to reverse. The thing is I think all of the differential and drive shaft is made by GKN which makes German cars and BMWs stuff I think, which are supposedly more refined and luxurious with no NVH problems but I know our driveshaft definitely has NVH problems.
They may have been trying to dampen and reduce vibrations in the driveshaft and that's why its so sloppy in the center support is my guess. This is the same reason that makes it supposedly weak too would be my guess as well. I wonder how the NVH and noise on the ZL1 is?
cmitchell17 is offline   Reply With Quote
Old 07-23-2021, 11:55 PM   #6
grampa_ss
grampa_ss's Avatar
I'm at 600+ for almost 3 years. No issues. I did install the safety loop during my last upgrade.
Old 07-24-2021, 08:54 AM   #7
Joshinator99
Moderator
It seems like PD blower + sticky tires seems to be the clear cut recipe for stock SS DS death. Everyone else is luck of the draw. That center section is *really* small...
