Old 03-15-2021, 03:16 PM   #1
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
Wide band newbe question
My tuner requested I get a wb sensor located in the position of aft position before I log with hptuners. I'm good logging and loading tune, but never used wb sensor before. Have another email into him, but if I need to buy one, what should I get, and do you temp replace existing stock one for the log or must weld in new bung? Trying to beat the fedx cutoff...
2017 SS 1LE only changes are cai, ported throttle body and new intake.
Thx
Ti.
Timbo-1LE is offline   Reply With Quote
Old 03-15-2021, 03:25 PM   #2
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Thx
Ti.
You only want the AEM wideband (https://www.hptuners.com/product/aem...troller-gauge/). It’s able to operate over the canbus and that lets you be able to data log your wideband in HP Tuners. Absolute no brainer.
I’d add a bung to your exhaust pre-cat for the wideband O2 sensor.
Old 03-15-2021, 06:37 PM   #3
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
Thx, just ordered.
Old 03-15-2021, 07:52 PM   #4
Joshinator99
Moderator
Thx, just ordered.
No problem
Old 03-15-2021, 11:26 PM   #5
NA18CamaroSS
NA18CamaroSS's Avatar
Drives: 2018 Chevrolet Camaro 2SS 1LE 6M
If you need ideas for gauge mounting:
https://www.aeroforcetech.com/images...single%201.jpg
https://www.aeroforcetech.com/products_gauge_pods.html
Easy to install and looks decent.
Bolt-ons.
NA18CamaroSS is offline   Reply With Quote
Old 03-16-2021, 08:26 AM   #6
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I agree with Josh and it is what I use. However I just want to clarify there are several Wideband's out there but most of them only work with HPt pro which has the WB input on the MPVI device. If you have the HPt standard then the AEM 30-0334 is the best option being it installs inline via the OBD2 port. This allows HPt to read the ECU and the WB at the same time.
KingLT1 is online now   Reply With Quote
Old 03-16-2021, 06:42 PM   #7
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
I have the older unit, will need to check.
Old 03-17-2021, 07:51 AM   #8
KingLT1
KingLT1's Avatar
Fwiw I have HPt standard with the older MPVI 1 device and the AEM 30-0334 works fine with it.
Old 03-18-2021, 11:25 AM   #9
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
+1
'20 ZL1 Black "Fury"
Old 03-18-2021, 06:18 PM   #10
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
Great, received today. Install this weekend
Old 03-21-2021, 12:00 PM   #11
rayhawk
rayhawk's Avatar
Drives: Cadillac CTS-V
Did you end up adding a bung to the factory exhaust before the cat? I assume this would require removal of this segment to accomplish.
rayhawk is offline   Reply With Quote
Old 03-21-2021, 06:46 PM   #12
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
Did not get to it, spent the day in the patio watching Sebring... Next weekend
Old 03-28-2021, 08:03 AM   #13
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
Bung welded in, tune loaded. Need to finish gauge and log, I need a vacation to focus
Old 04-10-2021, 10:54 AM   #14
Texan4iu
BLEW BIU
Texan4iu's Avatar
Drives: 2018 2SS 1LE Hyper Blue
Hopefully the bung is at least a 10 degree angle (between 10:00 & 2:00 on a clock) per the AEM instructions. My bung came predrilled on my exhaust, but was not angled. I'm on my 5th or 6th sensor in a year's time. AEM told me the angle isn't that important, but I'm tired of changing them out each time one fails. So I'm going to have another bung placed at an angle.
Just curious, who is your tuner?
Texan4iu is offline   Reply With Quote
