![]() Drives: Canadian 2019 BLACK ZL1 Join Date: Feb 2020
First Oil changing
Hi guys
As you could see it’ s gonna be thé first oil change. Thé problem is that here in France no garage want to do it. So I’m going to do it by myself but... I’m a poor mechanical... and afraid to make mistakes... Thé oil is 0w40 and I got it in castrol 1) how many liters needed ? 2) is there a gasket to change for thé o ring and of there is one thanks to tell me the référence to order it. 3) thé oil filter : could you tell me the best and the référence to order it (on the same web site would be cool) ? 4) Is there also a oil filter gasket ? Thanks to all of you Have I forgotten something ? For thé oil changing is there something spécial or complicated ... Don’t be shy to tell me all you know cause as I said I’m a fool mechanical lol
![]() ![]() ![]() Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
Motor oil - Mobil 1 0W-40 ESP formula* dexos2
Engine filter PF64 12696048 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
10 quarts of oil
The oil filter is a total replacement, the gasket is attached. When removing the old filter verify the gasket came off with the old filter. That’s always good practice Order a genuine ac delco oil filter pf64 You need a good oil filter wrench. I install my oil filter by hand and only use the wrench to remove I use something like this https://www.amazon.com/ULTRACRAFT-UL.../dp/B07D1HMT5B The oil chnage is very easy, you don’t need to remove any panels or plates. The filter installs vertically so you can prefill the oil filter with oil prior to screwing it on. You have high likely hood to not spill a drop of oil with this car. You can reach the filter by reaching from behind the front driver side wheel.
Also make sure you check the oil level correctly it should be in the owners manual.
#5 | |
![]() Drives: '19 ZL1 1LE A10 ShadowGrayMetallic Join Date: Mar 2019
This is the correct oil. https://www.jegs.com/i/Mobile+One/65...RoC2q4QAvD_BwE |
#6 | |
That oil looks correct but for some reason it doesn't say Dexos2. I usually order from here as a kit. https://www.speedwaymotors.com/Mobil...it,386340.html |
#7 |
Oh so great... à quarter is equal to a liter if I well anderstand....just another question ... why did you say my oil isn’t good?
It’s 0w40 castrol dexos 2 ... this is not right ? Otherwise I’m gonna order thé kit 20bluezl1 this excatly what I need and I think the price is really fair... |
#8 | |
#9 |
#10 |
No gasket
#11 | |
Also I wasn't even aware the Castrol made 0w-40 dexos 2 I know they make 0w-40 but it's not dexos 2. Do you happen to have a picture of the bottle? |
#12 |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
According to GM there are but 2 licensed 0w40 dexos2 oils. One of those is Castrol &, the other, Mobile-1.
https://www.gmdexos.com/brands/dexos2/index.html That is not to say there aren’t others that meet the specification requirements, but only 2 that pay royalties to GM to carry the Dexos2 labeling. |
#13 | |
#14 |
