Old 03-12-2021, 06:44 PM   #1
Tayley1LE
Drives: 2017 1LE
Dead Battery?
My 2020 ZL1 is acting funny. Can't get it to start off boost and just came in the garage and the wipers are going. Is battery shot or is it possessed? Car has 300km on it. No I did not trickle charge it this off season. Started it a couple times. Heated garage.
Tayley1LE is offline   Reply With Quote
Old 03-12-2021, 08:46 PM   #2
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
Man that’s strange. I left mine at least two months in my unheated garage and I’m not too far from you. Started right up but slower cranking I’m sure due to cold and battery drain. Wipers on??? That’s weird.
Old 03-12-2021, 08:57 PM   #3
1hprush
2018 ZL1 1LE
1hprush's Avatar
Drives: 2018 ZL1 1LE
When the battery starts to go, it's not so unusual to see signs of it through your cars electronics, or in your case, wipers. If it's not totally drained, I would try a battery tender, but if it's shot, it may not even charge. This at least is a good starting point.
Current: 2018 ZL1 ZLE
Memories:
2017 50th Anniversary Camaro Convertible (Sold)
2003 Dodge Viper (Sold)
2005 Lingenfelter Corvette (Sold)
2004 Mazda RX-8 (Sold)
1hprush is offline   Reply With Quote
Old 03-12-2021, 09:17 PM   #4
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
confirm battery voltage...take the battery leads loose from battery to charge. Attempt to restart after a low amp overnight charge of battery. Boost sometimes does wacky things when the battery is really dead and you are trying to "kick it up" quickly
Old 03-14-2021, 03:06 PM   #5
Tayley1LE
Drives: 2017 1LE
Thanks for all the help. I put the battery on charge and it started the next day. I let it run for awhile and seems okay except for engine light is on now. I put the trickle charger on it and left it for 24hrs and it is showing charged. I was told it didn't like me messing with it so much trying to boost it and probably set off a sensor. We'll see if it goes out once I start using it. Sure was nice to hear the beast come to life!
Old 03-14-2021, 03:48 PM   #6
Scottyz
Scottyz's Avatar
Beautiful brother
Old 03-14-2021, 04:48 PM   #7
2018ZL1
2018ZL1's Avatar
Drives: 2018 ZL1 A10 NFG 2019 COPO 350 SC
Really nice looking ride you got there!!!
2019 COPO #32
350 SC
8.25 167MPH
2018 ZL1-NFG-A10
388CI L8T
9.32 147MPH
2018ZL1 is offline   Reply With Quote
Old 03-14-2021, 09:53 PM   #8
1hprush
2018 ZL1 1LE
1hprush's Avatar
Looks great! A few engine cycles and you'll probably lose the cel (check engine light). Glad it worked out.
Memories:
Old 03-14-2021, 11:20 PM   #9
gtfoxy
Drives: '21 Wild Cherry ZL1
As I discovered here AGM batteries require a specific charge & maintenance.
A standard charger is no bueno.
