Old 03-12-2021, 06:03 PM   #1
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
LT2 Intake Manifold on Today
As the title says, I installed my LT2 intake manifold today. It really is a PITA to install initially, Should be a lot easier if I need to do it again though. 1st start up was good, a 7 mile aggressive drive was good also. Restart at home after checking stuff and tweaking harness connections , I got a cel. Drove it two separate times for a total of 25miles and still the cel is there. I need to borrow a scanner to see what code I have to determine problem. I also rechecked torque on all 10 intake bolts and it took quite a few turns to get them back to 75 in lbs, that bothers me. The car runs fine, but I do notice a slight loss in Idle RPM, may 50rpm, not even 100 rpm. Am using my stock air intake , that requires a little muscle to twist and stretch both ends and tightening the clamp to keep it where you want it. Various plastic vacuum lines need to be tweaked in different angles and positions and unclipping the pass side fat harness so it can be pulled foward a little to take pull off one of the clipped on wire harness connections. Positively cannot use the insulation piece that sits on top of the valley under the OE intake . Will be happy to answer anyone questions.
lt4camaro is offline   Reply With Quote
Old 03-12-2021, 06:33 PM   #2
BLACK21SS
Oldman w/a teenager brain
BLACK21SS's Avatar
Drives: 2022 ZL1 A10
Not being facitious, but why? I'm still learning.
BLACK21SS is offline   Reply With Quote
Old 03-12-2021, 06:36 PM   #3
lt4camaro
lt4camaro's Avatar
Because there is a proven gain of 20 hp between 5000 and 6500 RPM and no loss of HP or torque in the lower RPM ranges. Also the intake is less than $230.
Old 03-12-2021, 06:43 PM   #4
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
I do mine on Saturday and paid Pray Performance to optimize it all in a few weeks (backlog of work).
Timbo-1LE is offline   Reply With Quote
Old 03-12-2021, 06:48 PM   #5
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
You might want to torque them down to the correct torque values.
1. First pass 44 lbs
2. Second pass 89 lbs
Even if your saying 75 to In./Lbs. (Nm) that’s 102 lbs.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 03-12-2021, 06:52 PM   #6
BLACK21SS
BLACK21SS's Avatar
There you have it. Thanks for the info.
Old 03-12-2021, 06:58 PM   #7
lt4camaro
lt4camaro's Avatar
Originally Posted by BlackbeastSS2 View Post
You might want to torque them down to the correct torque valves.
The 75 in lbs spec comes from the aftermarket intake spec sheet along with the torque sequence. Just not liking the feel of torqueing the intake that tight. I did 25, 40, 75 , than 75 again after driving and intake was fully warmed. The aluminum on aluminum throttle body torque feel is much better and what I am used to feeling.
Old 03-12-2021, 07:01 PM   #8
lt4camaro
lt4camaro's Avatar
Let me know how it goes for ya. I consider myself a decent wrench and it was a little bit of a bitch to get thinks so so.
Old 03-12-2021, 07:09 PM   #9
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Now you should get a Roto-Fab CAI for your LT1!
Old 03-13-2021, 12:35 AM   #10
GrayLT1
Drives: Chevrolet Camaro
Yeah I’m definitely interested in what is causing the cel. Got my intake ready to go on.
GrayLT1 is offline   Reply With Quote
Old 03-13-2021, 12:39 AM   #11
s346k
s346k's Avatar
Drives: like an old lady
low idle and codes? vacuum leak?
Old 03-13-2021, 06:49 AM   #12
lt4camaro
lt4camaro's Avatar
Thank you for the suggestion. I opened up my OE air box by smoothing out the upper and lower halfs from all the fins and opened the front of the air box so it draws cool air under and in addition to the OE inlet. The additional air inlet source is sealed like the OE inlet so it has no chance of drawing under hood heat air. I also removed the snow block rubber and trimmed the lower flange on the left headlight so now I can look thru the grille and see right into the air box. My air box is cold to touch as is the throttle body (Same as ambient air temp) on a cool day after a drive proving it draws outside ambient air only. Not so sure the Roto Fab totally isolates under hood hot air from being inhaled and so far no cost.
Old 03-13-2021, 06:53 AM   #13
lt4camaro
lt4camaro's Avatar
Yeah, I am thinking along those lines also and the cel was not immediate or even during the first 7 mile drive. Cel after 1st restart when it was shut down for about 15-20 minutes.
Old 03-13-2021, 09:57 AM   #14
Aragorn
Drives: Camaro SS 1LE
So much cheaper than msd— very tempting!
Aragorn is offline   Reply With Quote
