Old 03-12-2021, 07:18 AM   #1
Dathomas94
Drives: Camaro 2021 ZL1 6 speed ragtop
Question Tail pipe color difference
I have a 2021 ZL1 with 1000 k on it I noticed when cleaning the inside of the tail pipes that the two outboard pipes have much more black carbon suit In them than the inboard ones..... any explanation?
Dathomas94 is offline   Reply With Quote
Old 03-12-2021, 07:19 AM   #2
Z OH 6
Drives: 2024 CT5-V Blackwing
Path of least resistance.
Old 03-12-2021, 07:22 AM   #3
ZLE dude
Drives: '18 ZL1 1LE
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
ZLE dude is offline   Reply With Quote
Old 03-12-2021, 08:25 AM   #4
Dathomas94
I see said the bling man
Old 03-12-2021, 08:28 AM   #5
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Drives: 2018 ZL1 1LE
Running in track mode all of the time, only the outboard ones get dirty.
Old 03-12-2021, 08:44 AM   #6
joekd
Drives: 2018 Camaro SS vert
Track mode uses only outer 2 pipes, mine does the same thing since I have the exhaust locked in track mode
joekd is offline   Reply With Quote
Old 03-12-2021, 09:56 AM   #7
Vigilante375
Drives: 2018 Camaro ZL1
When the exhaust is set in stealth, the 2 inboard pipes are used. When sport or track is used, the 2 outboard pipes are used. I'm not sure about tour but maybe the 2 inboard ones are used. Mine is either set to stealth or track when I drive 95% of the time is set to track and my 2 outboard pipes are very black.
I'm not one to clean tail pipes because it's a waste of time, IMO. I spend enough time cleaning the brake dust.
But even if you set the exhaust to stealth when you go full throttle, it'll switch to the 2 outboard pipes.
Old 03-12-2021, 10:15 AM   #8
willzilla
D3RPZILLA
willzilla's Avatar
Drives: 2021 Camaro ZL1 a10
What is everyone using to clean the tips?
Website: z1lla.com | YouTube: sub.z1lla.com | Merch: Shop & Etsy
YouTube Playlists: Performance Mods | Show Mods | Other Mods
willzilla is offline   Reply With Quote
Old 03-12-2021, 10:33 AM   #9
Tara Martin
Loves Camaros
Tara Martin's Avatar
Drives: Red '79 Z28, '24 Blk A10 ZL-1 Vert
I use a (don't laugh) toilet brush. I bought one just to use on my tail pipes.
Seems to work!
Tara
Old and new, sharing space!
Tara Martin is offline   Reply With Quote
Old 03-12-2021, 10:35 AM   #10
The outer pipes that are controlled by the NPP valves are not muffled, so when the valves open, those are nearly (short of the minimal perforated sections) straight pipes downstream from the secondary cats.
These are the products I use to clean the tips, in increasing order of strength and abrasiveness and depending on how dirty they are:
Tub O' Towels
Nevr Dull
Mother's Mag & Aluminum Polish
Old 03-12-2021, 12:17 PM   #11
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Metal polish. I think that I'm currently using Mother's.
Old 03-12-2021, 12:41 PM   #12
Snowwolfe
Drives: CTV5 V Blackwing on order
The tips are the last thing I wipe down with the microfiber towel before tossing it into the wash bin. If needed, a dab of any metal polish will help.
2022 CT5 V Blackwing with A10
2021 GMC Denali pickup with 6.2 and A10
2017 Ford Expedition
Snowwolfe is offline   Reply With Quote
Old 03-12-2021, 01:02 PM   #13
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
i use a mothers metal spray polish with a rag after i go on track but on normal driving in tour or sport mode they are fine
Old 03-12-2021, 01:13 PM   #14
Rhobz
Rhobz's Avatar
Drives: 2018 Camaro 1SS 1LE
Someone posted the idea of painting the inside of all 4 tips black so they match all the time. I think I will end up going this route.
Rhobz is offline   Reply With Quote
