03-11-2021, 06:37 PM | #1 |
Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
Child Trunk Release
I forgot I was going to ask this.
So I got my car out of storage the other day. When I put it away I took the battery out to bring it home to keep it on a tender as my storage unit does not have electricity. Anyway, not even thinking about it when I put it away, I shut the trunk all the way. Well when I went to put the battery back I obviously couldn't get in the trunk. I folded down the back seat to crawl back there and sure $hit, the child safety release does not work. I was able to push over the latch with a small screwdriver, but I need to figure out why that child release doesn't work. I pull on it and I can see the latch mechanism move a little, but it won't pop open the trunk. Anyone ever have that thing apart? |
03-11-2021, 06:54 PM | #2 |
Drives: 2017 1SS Hyper Blue Join Date: Apr 2017
Jay, it might be if there is too much tension on the latch. Happens with the electric release sometimes. Try having someone push down a bit on the trunk while you work the release.
03-11-2021, 07:42 PM | #3 |
03-11-2021, 09:08 PM | #4 |
Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
Perfect conclusion to why we needed this in the first place!
Someone trapped "ask someone to push down I while try to escape"!
2023 Camaro ZL1 Vert TR-6060 Sharkskin "Sharky"
Firecracker Red Wrangler Willys, 3.6L eTorque, 850RE 8 speed automatic, 25W Willys package, Technology Group, Convenience Group (aka $600 garage door opener), Cold weather Group, Trailer Tow and HD electric group with AUX switches, 3 piece black freedom top. |
03-12-2021, 07:53 AM | #5 |
Hot Camaro
03-12-2021, 08:31 AM | #6 |
I can almost guarantee you that nobody ever tries to make sure that child latch release works. I can say I've never checked one in any of my vehicles until now. I will figure out why this one isn't working and fix it.
03-12-2021, 08:36 AM | #7 |
That is exactly what the problem is. I opened the trunk and with the trunk open closet the latch. When I pull the child safety release it works just fine. So it's definitely tension when it's closed causing it not to work.
03-12-2021, 08:46 AM | #8 | |
Hot Camaro
The WORST part of that failure is that only the smallest of children could fit in that trunk... They are the ones the least-capable of using the release. |
03-12-2021, 09:03 AM | #9 |
Drives: '21 Camao SS, BMW 435i, M Roadster Join Date: Oct 2020
Wouldn't this be considered a safety issue? If so, you may want to send a note to NHTSA and copy GM. You may even save a life.
2021 Camaro SS Riverside Blue Metallic
2014 435i M-Sport, Mineral Gray, Black Dakota Leather, Driver Asst Pkg, Prem Pkg, Tech Pkg, 8 Spd Sport AT, Heated Front Seats, ACC, BMW M Perf Tune w/MPE, BMW LSD, BBS CH. 2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Steel Gray Metailic HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. |
03-12-2021, 10:10 AM | #10 | |
03-12-2021, 10:15 AM | #11 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
03-12-2021, 02:47 PM | #12 |
I'm not sure, but I think some safety issues are covered long after the warranty runs out.
03-12-2021, 03:23 PM | #13 |
Drives: 2018 SS 1LE Join Date: Apr 2017
03-12-2021, 04:24 PM | #14 |
