![]() ![]() ![]() Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
Brake fluid
So im about to replace my stick brake fluid for some Dot 4. I've been reading alot and I'm between a couple of fluids. What are guys using and why.
- Brembo HTC 64T - ATE Super Blue/Type 200 - Motul RB 600 - Motul RB 660 - Castrol SRF I'm leaning towards the Brembo HTC 64T as I've read good things but I'm worried why does it say not for street use and also don't use if yiu have magnesium parts. Also they never post specs but I believe they are the only fluid used by F1. - As for the Motul read it needs to be changed very frequently snice it absorbs moisture quickly. - ATE read great things but also read only good for street. - Castrol SRF read great things but also it's over rated for the price. I'm open to suggestions |
![]() ![]() ![]() ![]() ![]() Drives: 2023 CT5 Blackwing, 2025 C8 Z07 Join Date: Sep 2016
You left out the most important info...
what are you doing with your car? How often do you plan on changing the fluid? If you track, then SRF is top, followed by Motul 660. Both have 'higher' change intervals due to their tendency to absorb moisture. For a street car that sees some canyon/mountain/curvy roads, I would go with Motul 600 and a yearly change. All of those fluids you listed with have significant reduction in their dry boiling points after a year (varies with climate). IMHO - I haven't run anything but SRF for the last 6 years. SRF's wet boil is higher than ATE's dry boil. I bleed after every track day and flush once a year.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 2025 Hysteria Purple C8 Z07 |
#3 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
The Endless fluid is also used in F1. Castrol SRF, Endless RF-650 and Ferodo Super Formula - cant go wrong with those for a racing fluid applicable to modern track cars. The Brembo fluid is good, but I wouldn’t use it unless I knew what was possibly magnesium in the brake system; however there are options just as good without the worry. Next up I’d say AP R3, Motul 600/660, StopTech 600/660 and Redline RL-600. |
#4 | |
![]() Drives: Camaro 1ss Join Date: Nov 2019
This year I plan on trying the Brembo HTC fluid. I mean F1 uses it so ![]() I'm not sold yet on the SRF at that price point. Edit: Pretty much all the fluids you listed will need to be changed out more frequent due to absorbing more moisture. I would say if your not tracking your car you shouldn't need the fluid.
Follow me on IG for build thread! https://www.instagram.com/tracked_1ss/
YouTube: https://www.youtube.com/@Tracked_1ss FortuneAuto Coilovers! https://shop-fortune-auto.com/produc...ries-coilovers Last edited by That1guy_tim; 03-09-2021 at 06:22 AM. Reason: added info. |
Sorry I did forget to mention my application. I will be track about 6 times a year and lots of hard curvy backroads. I don't daily my car.
I was looking for a fluid that I wouldn't have to replace that often. Bleed the system I guess is not a big issue but replacement of the entire fluid is more of a hassle. |
#6 | |
#7 | ||
![]() ![]() ![]() ![]() ![]() Drives: 2013 C6Z06 Join Date: Nov 2016
Also SRF doesn't need frequent changes that's the beauty of it's high wet boiling point. Quote:
Old Ride: 2016 Callaway SC630 Camaro SS
#8 | |
Yep so I just realized that SRF is 1L and all the rest or 500ML so the price difference is not to much. How many 1L SRF should I get to flush the old Dot 3 out? |
#9 | ||
Honestly, yes, there is a lot of hyper with SRF, but it is an awesome fluid... Where it shines above the rest is really in that it needs less frequent bleeding and will last a lot longer in the brake system. I've tried both Motuls (600 and 660), StopTech 600, Castrol SRF and Ferodo Super Formula in my Camaro over the past years and in other cars. I can confidently say that I did notice that SRF does not require as frequent bleeding and keeps a consistent pedal feel throughout the duration of laps and over an entire season. Quote:
StopTech is very similar to the Motul. I actually think it is maybe a touch better, but nearly the same. The Ferodo fluid has not given me any problems, but does seem to need regular bleeding of the system after hard track use. I will be trying the Endless fluid next up. You can get away with a single 1L bottle. |
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
i have motul 660 bleed it once a year change it out once a year no problems
#11 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
PS Based on posted experiences in the past i avoid Motul. |
#12 |
Ok so looks like I'm going with the SRF. Now I will buy two 1L bottles to be safe. Also looking for the motive power bleeder but I see mixed reviews. Some say they leak with etier the metal or plastic cap. What should I get?
#13 |
![]() Drives: 2019 ZL1 1LE Join Date: Sep 2010
I got the one with the plastic cap, it works great and doesn't leak. I used the thin gasket and lubricated it with a tiny bit of brake fluid. Just be 100% sure it's not leaking before you pressurize it with brake fluid.
#14 |
![]() Drives: 2017 1ss 1le HBM Join Date: Jun 2020
I use the ATE Type 200. They don't make the blue anymore even if it says that on the can. I do bleed the brakes before each event I go to and so far it has been good. I have the Motive bleeder with the metal cap and it works great!
