Old 03-07-2021, 07:11 PM   #1
Hambo864
Drives: Chevrolet Camaro SS 1LE
Headers for Corsa Double Helix
I have spent the entire weekend researching long tube headers in an attempt to find a set of headers that will bolt to the Corsa Double helix exhaust on my car. If anyone has dealt with this issue, I'm trying to figure out the easiest, most cost efficient decision. I'm not looking for a brand, I'm looking for fitment. Thank you
Hambo864 is offline   Reply With Quote
Old 03-07-2021, 08:31 PM   #2
enzia35
Drives: '16 Garnet Red 1SS
Any headers from a different brand will need some fitting.
'16 Camaro 1SS
'18 Miata GT
Old 03-08-2021, 01:02 AM   #3
Pens
Drives: 2019 SS 1LE
I have the corsa x pipe and from what I understand you have to purchase the connection pipes from corsa to connect to headers. Now I’m not sure if that’s specific to the corsa headers only or to any headers.
Pens is offline   Reply With Quote
Old 03-08-2021, 01:09 AM   #4
Pens
Drives: 2019 SS 1LE
Basically these corsa connection pipes should replace and connect to the areas circled black and the red circled area should connect to any headers. Someone correct me if I’m wrong cause I’m not 100%.
Old 03-08-2021, 07:25 PM   #5
Hambo864
Thank you Pens. That was exactly what I needed to see to help me out. I found some Corsa headers with the connectors but ultimately decided to go with a set of Kooks with their connection pipes. I know there will be some cutting and welding that I'll have to do but I'm just gonna deal with it.
Old 03-08-2021, 09:22 PM   #6
Pens
Drives: 2019 SS 1LE
No problem. I was going to start a thread asking the same question when the time comes to get headers as I already have the corsa x pipe and just purchased a kooks straight pipe (no mufflers) axle back. Let me know how the connection to the corsa x pipe works with the kooks setup when you get it on.
