2017 SS Auto Start
Just got a 2017 SS Camaro do you know if they all came with autostart. If so mine is not working. Thanks!
![]() Drives: 2018 Camaro SS vert Join Date: Oct 2020
Are you hitting lock first then start? Do the cars lights blink in response?
Yes I am And the lights do blink.
Ok...then what happens? Does it start and stop? Not try to start at all?
Hard to troubleshoot without knowing the whole story
It does not start at all. How can I tell if I even have auto start? Also Tried both key FOBS
#6 | |
Drives: Fast if no one's looking Join Date: Aug 2019
It is standard on all Camaro automatics since 2016 and not available on manuals. |
#7 |
![]() Drives: 2017 Camaro 1SS, 2023 Sierra Join Date: Feb 2014
Car won't remote start if the hood isn't fully closed and latched, is that a possibility?
#8 |
![]() Drives: 2017 Camaro 2SS Join Date: Mar 2019
I have to hit my remote start button after I hit the lock button 2-3 times and hold it down before it'll start. My car has always been a disrespectful bastard with key fobs...
Gary
2017 2SS A8 White, Bolt-Ons, Prayed Upon |
#9 |
...but holding it down is the normal procedure. Press lock, lights blink, then hold engine start down until lights blink again, then you can release the engine start button, the car should crank within a second. Works 100% of the time for me, and we have the same software (most likely).
#10 |
![]() Drives: 2017 Camaro 2SS Vert Join Date: Apr 2019
Your key fob, how many buttons does it have? I had to tell my car lot I would not buy without a fob with the remote start. The gave me one fob without the remote start till I told them that. Easier to get another fob the bot make a sell. You could be in the same situation.
#11 |
Long hauler
Could be like Drew said with having the wrong fob, the conditions of auto start I believe are if there’s a check engine light or warning the car can detect then remote start is disabled until that light has been addressed
2016 1LT v6 - Totaled Happiness: Infinite |
#12 |
Update I found out the issue today. My check engine light was on and there was an issue with the emission controls. According to the manual that will disable the auto start feature.
Took it to the dealer and found out one of the cats are bad. |
#13 |
Bad Cat!
Good Boy!
