03-01-2021, 08:43 PM | #1 |
Drives: 2019 2SS 1LE Join Date: Feb 2021
Memory seat issues....
My memory seat feature is very hit and miss as is the exit feature. Is this common with these cars?
03-01-2021, 08:46 PM | #2 |
Drives: Fast if no one's looking Join Date: Aug 2019
Sure you’re in the right place? The Chevy dealer might not take your Your Scat Pack Charger in if your memory seat issue is under warranty
03-01-2021, 09:04 PM | #3 |
Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
My seat memory works perfect every time, including the exit feature. I say user error.
Turning off car too fast on exit - opening door? Putting car in gear too fast on start up, go to gear before seat is positioned Stuff like that. Mine works every time.
2023 Camaro ZL1 Vert TR-6060 Sharkskin "Sharky"
Firecracker Red Wrangler Willys, 3.6L eTorque, 850RE 8 speed automatic, 25W Willys package, Technology Group, Convenience Group (aka $600 garage door opener), Cold weather Group, Trailer Tow and HD electric group with AUX switches, 3 piece black freedom top. |
03-01-2021, 09:17 PM | #4 |
03-01-2021, 10:51 PM | #5 |
Mr. Fran is on point here. Mine has worked flawlessly as well - since I figured out the finer details. Its really easy to negate the operation and not realize it.
#SaveTheManuals
03-01-2021, 11:54 PM | #6 |
The Wicked Jester
Drives: 2020 Camaro 2SS Orange Crush Vert Join Date: Sep 2012
Make sure that you have the Memory Seat functions turned on in the Infotainment Section of the car - see if they are set up on the Auto feature instead of Off. I had issues with mine when I set it at first - it wasn't working - I then found the settings in the Infotainment menus - now it works great - when I turn off the car then the seat goes all the way back. When I start it - then it moves into my Seat 1 position...
I hope this helps you out...
New Car (His): 2020 Camaro Orange Crush Convertible 2SS
New Car (Hers): 2020 Camaro Satin Steel Metallic Convertible 2LT/RS Redline Package Old Car: 2014 Camaro Summit White 2SS/RS Old Car: 2010 Camaro Inferno Orange 2LT/RS |
03-02-2021, 12:43 AM | #7 |
Drives: 2018 camaro 2LT Join Date: Nov 2020
also, make sure you are using the same key fob every time if you have 2 keys/users/settings. i put a black cover on my key and red for my spare which my old lady would use, and set for her, if she wants to drive the car
03-02-2021, 01:11 AM | #8 |
Drives: 18 Camaro 2SS Join Date: Jul 2019
I was recently having an issue with the back only part of the seat not functioning. The rest of the seat would work, going into and out of position both manually and on auto. Hit or miss as well. Had it at the dealership for a new rear diff and mentioned the seat thing. I was told they had to do an update on the programming. It’s worked fine since.
03-02-2021, 02:44 AM | #9 |
If you have a manual transmission, you also have to set the parking brake before opening the door.
I found this out myself wondering why my auto exit wasn’t working. |
03-02-2021, 06:49 AM | #10 |
I don’t ever use mine but I noticed that it only works half the time anyway.
03-02-2021, 07:16 AM | #11 | |
Also, the key to the seat engaging upon startup is making sure the door is closed. Then you press the start button. Now, since I have my seat so far back for egress I can't reach the pedals, when I get in I first hit the start button to engage accessory mode, and that moves the seat to my driving position. Then I can reach the brake and clutch, press them, then press the start button again to start the engine. |
03-02-2021, 07:43 AM | #12 |
Hot Camaro
I seem to recall a YouTube video of a woman that owns a 'vette going through the setup process to ensure that the memory seats are set correctly and work correctly. I believe it would apply here as well...
03-02-2021, 07:49 AM | #13 |
Mine stopped working after a recent software update. I instinctively adjust it manually depending on where I'm going but need to check it out again
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. Not a DD. |
03-02-2021, 08:02 AM | #14 | |
"60% of the time, it works every time"
