Old 03-01-2021, 05:11 PM   #1
1LEASYE
Drives: 2018 Camaro 1SS 1LE
Road Atlanta sound check
I am going to Road Atlanta for the first time this weekend with NASA and I know Sundays between 10AM to 12 noon is the quiet time for the churches.
My exhaust is the non-NPP stock exhaust but I wanted to ask are the sound check stations usually in the same spots on the track or do they move around like how I've read Laguna Secs does now?
I always run the exhaust in Track mode through the Engine Management option in the infotainment screen on top of Track Mode itself and I know the non-NPP exhaust for the SS 1LEs is right on the limit for most tracks that have decibel level checks.
2018 Camaro 1SS 1LE
1LEASYE is offline   Reply With Quote
Old 03-01-2021, 07:51 PM   #2
TWG1
TWG1
Drives: 2019 Camaro ZLE
I got black flagged on a completely stock ZL1 (NPP, track mode) during the Sunday quiet hours. IIRC, the sound meter was near turn 7. I don’t think the NPP mode matters, as the valves open under WOT in all modes.
2019 ZLE M6
2019 ZL1 A10 (Sold)
1967 Jaguar XKE Series 1 Roadster
2021 F150 Powerboost (on order)
TWG1 is offline   Reply With Quote
Old 03-01-2021, 09:44 PM   #3
1LEASYE
That sucks, sounds like I have to go snow/ice mode for the exhaudt settings then or just let off the throttle near turn 7.
2018 Camaro 1SS 1LE
Old 03-01-2021, 09:47 PM   #4
TWG1
TWG1
Realistically, it’s only one session with most organizations. You can probably still run track PTM modes, just override exhaust in infotainment vehicle settings. Also, my car was A10, so always in high revs. An M6 would be easier to manage.
2019 ZLE M6
2019 ZL1 A10 (Sold)
Old 03-02-2021, 08:42 AM   #5
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
You mean your exhaust is the NPP. Non-NPP can't change modes as there are no valves and therefore no modes. Also you can't buy a 1LE without NPP.
Old Ride: 2016 Callaway SC630 Camaro SS
Old 03-02-2021, 10:58 AM   #6
1LEASYE
I actually didn't know either of the above statements, I thought it was possible to get a 1LE without the NPP exhaust?
2018 Camaro 1SS 1LE
Old 03-02-2021, 03:42 PM   #7
Loaded Goat
Drives: 2019 ZL1 1LE Black/Black
what group are you running in?
Loaded Goat is offline   Reply With Quote
Old 03-02-2021, 07:06 PM   #8
1LEASYE
I'll be in HPDE1 it's my first time at that track
2018 Camaro 1SS 1LE
Old 03-02-2021, 09:55 PM   #9
NorthGeorgia
Drives: 2018 ZLE, 2023 C8, IMSA MX-5
Enjoy, RA is fast and not forgiving, video helps,,
Re sound on sunday, Coming out of turn 7 on to the back straight, you will have to keep it out of WOT, sound station is usually to the right at the bridge,,, just dial it back and stay back from others, else you get caught in corner exit back straight passing mayhem ,,, with the M6, you can short shift before the bridge and short shift well before T9 ,,,, the back straight invites dangerous speeds going into the downhill chicane 10a/10b, anything north of 145 on the back straight just consumes brakes going into 10, and north of 155 leaves no room to miss your brake mark or fade ,,,, the gravel trap at 10a was designed to catch sub 2500# cars at 180,,, not 3800# cars at 155+,,, too much retained energy,,,,
NorthGeorgia is offline   Reply With Quote
Old 03-04-2021, 07:43 PM   #10
weemus
Drives: 2017 1SS 1LE
I was black flagged for no lift shifting at WOT going past the sound check. I did it just to see if I would hit the sound limit. I just short shifted the rest of the session with no further issues.
weemus is offline   Reply With Quote
Old 03-05-2021, 11:00 AM   #11
ponyboy96
ponyboy96's Avatar
Drives: 2020 ZLE A10, 2018 F250 Diesel
Yes you will likely get black flagged. I got black flagged in my completely stock ZLE A10. If you are an m6 and can keep the revs low you should be fine. Just use the time to work on your lines and go slow. Last time in was at RA was Dec NASA event. We had 2 sessions during that time in DE2. 1st session I got black flagged. 2nd session I just put it in tour mode and rode around the track. Fortunately we had 5 sessions that day.
ponyboy96 is offline   Reply With Quote
Old 03-05-2021, 11:12 AM   #12
TheRealJA105
Drives: 2013 C6Z06
Probably too late, but do this https://www.camaro6.com/forums/showthread.php?t=586579
Old 03-05-2021, 02:58 PM   #13
thescreensavers
thescreensavers's Avatar
Drives: SW 1SS 1LE / Jeep XJ
With my NPP exhaust and secondary cats removed in silent mode I was able to go full out. Didnt help mustangs in the group had the whole session black flagged :/
thescreensavers is offline   Reply With Quote
Old 03-05-2021, 05:21 PM   #14
1LEASYE
Ah yes the ever handy Laguna pipes, I'm going to make myself a set when I get back.
2018 Camaro 1SS 1LE
