Old 02-23-2021, 11:28 AM   #1
sspddmn
sspddmn's Avatar
Drives: 2018 ZL1 1LE and 1991 Z28
Noob question regarding lowering front end ZLE
Ok first of all i apologize if this has been talked about before but i have tried the search function several times and i keep getting a http error 500. So....
I've only had my ZLE for 5 months so I'm still kinda new to the ZLE. When i bought the car the front suspension was already in the track setting as indicated by the top of the struts. After purchasing it used i took it to a (trusted) dealer to get the fluids changed. I asked my guy to put the suspension back to street settings so i dont wear out my tires. After doing so i noticed that the front wheel gap is noticeably bigger. So my questions are:
1. Does switching between track and street settings change the height of the car or only the camber of the wheels?
2. Can i adjust the height (lowering) of the car via the dssv's? I think i read somewhere that i could but not 100% sure.
3. If so can i adjust the rears as well?
4. By adjusting the height will this cause wear on the tires?
Thank you in advance
In the garage: 2018 HBM ZL1 1LE // 2013 ZL1 (sold) // 1991 Camaro Z28 5.7L // 2022 Audi E-tron SUV (wife's car) // 2002 Camaro SS (sold)
sspddmn is offline   Reply With Quote
Old 02-23-2021, 12:09 PM   #2
AZ_1LE
Drives: 2019 ZL1 1LE
No, changing the camber does not change the ride height. It's purely visual as the tire goes from being leaned in a noticeable amount to being just about a square with the fender edge.
Yes, you can lower the front via the lower spring perches which are adjustable.
If you adjust the ride height, you'll change the toe settings and you'll start getting increased wear.
Old: 2017 SS 1LE
Old: 2017 ZL1
Current: 2019 ZL1 1LE
AZ_1LE is offline   Reply With Quote
Old 02-23-2021, 01:24 PM   #3
sspddmn
sspddmn's Avatar
Ok thank you for the info. Guess i wont be adjusting the ride height.
Old 02-23-2021, 02:40 PM   #4
Zl1+911
Drives: 997 GTS, ZL1 A10, ZLEM6, ZLEA10
you can adjust the ride height to your liking and and the car realigned ....
Zl1+911 is offline   Reply With Quote
Old 02-23-2021, 07:13 PM   #5
sspddmn
sspddmn's Avatar
I thought about that too but wasn't quite sure. I'd hate to wear out a set of $2k tires just driving it a few times a week. I only want to adjust/lower the front because i see some photos of ZLE's where the front wheel gap is very minimal compared to mine. Thanks for the input.
Old 02-23-2021, 08:01 PM   #6
1hprush
2018 ZL1 1LE
1hprush's Avatar
Congrats on the purchase! You're really going to love this car too. How many miles on it when you bought it...a pic of the wheel gap you speak of may help.
Current: 2018 ZL1 ZLE
Memories:
2017 50th Anniversary Camaro Convertible (Sold)
2003 Dodge Viper (Sold)
2005 Lingenfelter Corvette (Sold)
2004 Mazda RX-8 (Sold)
1hprush is offline   Reply With Quote
Old 02-23-2021, 08:24 PM   #7
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
Car comes in middle height setting and looks great there, but -3.0 camber helps the look too. I would do lowest setting for potential better handling and more aggressive aero angle for more downforce, but the steep driveway of my hillside house doesn’t allow it. At middle height I clear no problem.
SFV1LE is offline   Reply With Quote
Old 02-23-2021, 10:37 PM   #8
sspddmn
sspddmn's Avatar
Thanks I appreciate it. I came from a 2013 ZL1 and upgraded to the ZLE. Bought it with 4350 miles on it. So far I've put 2000ish miles on it. So far I love it. The ride I just had to get used to it. Lol
Here are pics of the gap. To me the gap is pretty wide compared some other ZLE's I've seen. (this pic was taken before i got new MPS4 tires.)
Old 02-23-2021, 10:43 PM   #9
sspddmn
sspddmn's Avatar
Thanks. I'll probably do that. For me the main thing is i don't want to cause uneven tire wear. So hopefully if i lower the front and get an alignment it wont cause the tires to wear.
Old 02-23-2021, 11:21 PM   #10
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Camber does not affect tire wear.... toe does.
Lower ride height = even shittier ride.. if that's possible.
If you bought 650hp camaro and you worry about tire wear..
Good alignment and you'll get good mileage out of the tires... you start changing shit without proper alignment, tires go bye bye FAST.
ing for grip.
http://www.motorsportsne.com/
Old 02-24-2021, 08:08 AM   #11
sspddmn
sspddmn's Avatar
Put it this way, I'm not worried about tire wear, I just don't want uneven tire wear. Theres a difference. I still have my 3r's for when I eventually do take it to the track and I know when you track the car there will definitely be uneven tire wear. I just don't want uneven tire wear for just regular daily driving on my street tires. I just wasn't sure if lowering the front even with proper alignment and tire pressure, if it'll still cause uneven tire wear.
