Old 02-23-2021, 10:32 AM   #1
Kemo Savy
Drives: Make it a 6 speed in SS trim.
WTF...anyone else use the USB Socket to Play MP3 Music?
I keep a small usb drive in my usb port to play MP3's through the infotainment. 60% of the time it won't recognize the device unless I totally pull it out and put it back in. The other 40% times it works fine. Its just hit or miss as to whether it works. For instance I can get in my car try to play it and it won't see it. Then I stop get gas, turn on the car retry it and it works. In any case it works anytime I pull it out the port and put back in. Anyone else have this issue?
Kemo Savy is offline   Reply With Quote
Old 02-23-2021, 10:35 AM   #2
DorsoDuroJohn
Drives: 2021 Camaro LT1
Mine works fine every time. 2021 LT1.
DorsoDuroJohn is offline   Reply With Quote
Old 02-23-2021, 10:46 AM   #3
ctrlz
This sporadic behavior has been reported several times over in the audio sub-forum.
The best solution is to try different brands of USB, as the controller chips in the drives vary.
I tried a few and ended up sticking with Samsung USB Bar. I see they now have a Bar plus, which is not what I have.
Old 02-23-2021, 11:00 AM   #4
Kemo Savy
I was using a standardard length drive before, cant remember the brand. Had the same issue then went with this compact one. Same issue.
https://www.staples.com/sandisk-sdcz...YaAqmTEALw_wcB
Old 02-23-2021, 11:24 AM   #5
oldguy0130
oldguy0130's Avatar
Drives: 2021 2SS red-line Camaro
On a related note, slightly off topic, if anyone has a USB thumb drive with music on it and the volume is different from one song to the next, I have found a fix. It is a shareware called MP3GAIN download. I have been using it for years. Just take the defaults and run it against your files. Make a backup first of course.
oldguy0130 is offline   Reply With Quote
Old 02-23-2021, 12:04 PM   #6
mrgoodwrench
The Wicked Jester
mrgoodwrench's Avatar
Drives: 2020 Camaro 2SS Orange Crush Vert
Thanks for the info regarding standard volumes...much appreciated...
New Car (His): 2020 Camaro Orange Crush Convertible 2SS
New Car (Hers): 2020 Camaro Satin Steel Metallic Convertible 2LT/RS Redline Package
Old Car: 2014 Camaro Summit White 2SS/RS
Old Car: 2010 Camaro Inferno Orange 2LT/RS
mrgoodwrench is offline   Reply With Quote
Old 02-23-2021, 01:13 PM   #7
ctrlz
Just looking through the sub-forum, there is no hard and fast rule. SanDisk ultra's seem to work, but not other SanDisk's. PNY works, but not sure which ones.
I had problems with SanDisk, Lexar, and a no-name. Settled on the Samsung Bar.
Old 02-23-2021, 01:17 PM   #8
FarmerFran
FarmerFran's Avatar
I use this...
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Format to FAT32, default size then put your songs back on. I have never had a problem with this dive in multiple cars including my current 2020 SS and multiple MFGs (Dodge, Jeep, RAM, Chevy, Ford)
Old 02-23-2021, 10:47 PM   #9
GroundhogSS
GroundhogSS's Avatar
I use this...
Does exFAT work? My win 10 system doesn't have FAT32 as an option. I had used NTFS and had lots of problems. Good to know that FAT might work.
Richard
Delivered: 08/15/2016
#TeamBeckyD
Old 02-23-2021, 10:55 PM   #10
FarmerFran
FarmerFran's Avatar
No clue, when I have ever formatted a drive for car use on my Win10 machines it always gives me the option to do NT/FAT or EX.
I always use FAT32 and 16K for the format
Weird how it does not have all 3 for you.
Plug in drive
This PC
"USB DRIVE"
Right Click
Format
Drop down for File system and Allocation Size has returns...
NTFS/FAT32 (DEFAULT)/exFAT
and
4,8,16,32,64 for size.
Old 02-23-2021, 11:12 PM   #11
GroundhogSS
Plug in drive
This PC
"USB DRIVE"
Right Click
Format
and
Nope, not there. May be different because it's 64 GB. Win 10 Pro.
Richard
#TeamBeckyD
Old 02-23-2021, 11:19 PM   #12
Brudda*Termite
Brudda*Termite's Avatar
Drives: 2017 Camaro 2SS
I always used the low profile Sandisk drives with the little leash dingus on it, and those work great. Bought some non Sandisk drives recently and they always give me problems with not being seen, starting over when I start the car, etc. Sticking with the Sandisk with the leash dingus version...
Gary
2017 2SS A8 White, Bolt-Ons, Prayed Upon
Brudda*Termite is offline   Reply With Quote
Old 02-23-2021, 11:22 PM   #13
FarmerFran
FarmerFran's Avatar
Ok, yes exFAT replaced FAT32. So in theory ex should work, but choose FAT32 file sizes.
Is 16K and option? if yes that would be my suggestion.
Old 02-23-2021, 11:32 PM   #14
GroundhogSS
Yeah, it's there. I'll give it a try.
One thing I did was replace the USB socket with one for a Silverado, as discussed on this forum. That includes an SD card slot. That works pretty good. Don't remember what I formatted that as. I'll have to check.
Richard
#TeamBeckyD
