Old 02-19-2021, 05:45 PM   #1
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
ZL1 1LE track camber strut pics
I had difficulty finding a clear pic or video which showed a nice picture of the correct orientation of the strut at "track camber". The GM performance manual only says turn the strut 180° until "track camber" is visible...pfft.
Jack and support the car on one side. I left the wheel on but you could remove it for better access. Use a 5mm or H5 allen wrench to remove the brass colored pin. The allen screw is tucked at the back/underside but accessible under the strut plate. The allen screw isn't tight at all so it is easy...grip the top brass protrusion as it will spin. Remove brass part from top and remove the allen screw from the bottom.
Next, remove the (3) 13mm strut plate bolts and set aside. Take some tension off the assembly by using the top of the wheel for leverage with your knee/arm/whatever. Do NOT use a pry bar or equivalent as shown in one Youtube...geez. Use a 19mm socket for the strut top and rotate clockwise while pressing the top of the wheel/tire inward and you will see the three bolt holes appear and the word "track camber". The GM supplement says 180° which is weird considering we are talking about a triangle here.
Reinstall the three strut bolts with your fingers and torque to 21ft/lbs. The brass pins do not fit at track alignment so save them in a safe place. See pics below for reference:
Old 02-19-2021, 09:34 PM   #2
Crushed 1LE
Crushed 1LE's Avatar
Drives: 2022 ZL1(FEA suspension) Rapid Blue
Nice write-up. Was about to do this in prep for my 1st track event next week.
Should be a sticky!
Crushed 1LE is offline   Reply With Quote
Old 02-19-2021, 10:32 PM   #3
ohsmily
Drives: '19 ZL1 1LE A10 ShadowGrayMetallic
Does that gold alignment detent need to be reinstalled when switching back? It seems unnecessary.
ohsmily is offline   Reply With Quote
Old 02-19-2021, 10:43 PM   #4
Stephen12ZL1
Drives: '21 ZLE A10
nope...it does not fit at track alignment...sorry for omitting that detail
Old 02-20-2021, 12:04 AM   #5
ohsmily
I mean when switching back to standard/street camber. Why bother putting the detent back?
Old 02-20-2021, 09:21 AM   #6
Stephen12ZL1
Drives: '21 ZLE A10
nah...not going back in mine.
Old 02-20-2021, 10:24 AM   #7
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
That lets you increase range for camber, does not FIX the toe that gets all jacked.
Doing this without toe adjustment will results in DESTROYED tires very quickly.
ing for grip.
http://www.motorsportsne.com/
Old 02-20-2021, 03:55 PM   #8
Checkmate1
Drives: Garnet Red / ZL1 1LE
OP - Thanks for this. Are you even going to bother switching back to the street camber/alignment settings?
I hit a max of 3 track events a year. Majority of my driving is back roads. Wondering if I should just leave in the track camber setting (-2.75F) all the time.
#SAVETHEMANUALS
Checkmate1 is offline   Reply With Quote
Old 02-20-2021, 06:28 PM   #9
Nightfall ss1le
Nightfall ss1le's Avatar
Drives: 2020 A10 ZL1 1LE
You don’t ever really need to switch it back anyway. You can get a good street alignment with the camber plates set to track anyway. Like another poster mentioned just make sure you’re setting your toe each time you change the camber.
2020 ZLE Roto-Fab dry
2018 Camaro 2SS 1LE - 2" TSP catless headers, Pray Ported stock IM/TB, Rotofab dry, DSX FF kit, dyno tuned by Pray. SOLD
Nightfall ss1le is offline   Reply With Quote
