Old 02-17-2021, 10:10 PM   #1
AdzyHany
Drives: 2021 camaro ss 1LE
Ported oem heads vs aftermarket heads
Hey guys.
I’m looking to spice up my 6mt 21’ 1LE. I know whp is just a number but I’m looking to get to 550 plus a 100 shot. I plan to do full bolt ons and heads/cam and tune. Will ported oem heads get me there? We don’t have E85 up here in Canada but I can get 94 octane from the pump. Thanks guys
AdzyHany is offline   Reply With Quote
Old 02-17-2021, 11:40 PM   #2
MrNoosNoos
Drives: 2019 Camaro 2SS 1LE
If you're going ported OEM heads, I would talk to PRAY performance about porting. Currently FBO E85 + cam @ 530 whp, adding ported manifold, mast heads, and pistons/rods. Hoping for 550+
MrNoosNoos is offline   Reply With Quote
Old 02-18-2021, 05:30 AM   #3
NYblack1le
Drives: 2018 1SS 1LE
I have CID heads with my n/a setup. I’m over 600whp with an msd manifold. Stock ported heads will get you where you need to be. Hit up Zack or James at GPI and let them know what you’re looking to do.
NYblack1le is offline   Reply With Quote
Old 02-18-2021, 08:03 AM   #4
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
if you want to go the ported oem route, pray performance hands down is the place to go. Some of his factory ported heads put big dog LS7 heads to shame. I believe his top two OEM ported heads flow 400+ CFM, which is just straight up ridiculous.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
Old 02-18-2021, 08:31 AM   #5
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
LT1 heads have some valves issues that seem to show up when you increase spring pressure, cam lobe intensity, and RPM. I believe Pray is around 4500.00 for a fully reworked set of ported OEM castings(New valve seats, valves, valve job, porting, springs...etc). However once he is done with them they seem to perform as good if not better then aftermarket stuff and even LS7 stuff as Dan mentioned.
I am not saying you can't get away with a port and valve job with new springs and hardware. Going that route is probably ok on something mild staying under 7k rpm. But if you are considering a more aggressive H/C setup with Nitrous on top it might be something to consider. Contact GPI or Pray and tell them what you are looking to do.
Old 02-18-2021, 10:47 AM   #6
Chris V
Chris V's Avatar
Drives: 2017 1SS 1LE
Stock bottom end?
www.facebook.com/1lap1le
2017 1SS 1LE - 663 whp/623 wtq
Rotofab/Whipple/Kooks 2"/LT5 TB/LT4 Fueling/E85/MCS Coilovers/Ground Control/GOODAero/Apex Wheels/Race Louvers
Chris V is offline   Reply With Quote
Old 02-18-2021, 11:51 AM   #7
NYblack1le
Originally Posted by Chris V View Post
Stock bottom end?
Gpi piston/rod.
Old 02-19-2021, 08:15 PM   #8
MrNoosNoos
Mod list?
Nevermind, I found it! Is the ATI dampener worth it?
Old 02-19-2021, 11:01 PM   #9
LT1ornothing
Drives: 2020 LT1 M6
Originally Posted by MrNoosNoos View Post
Mod list?
It is worth it if your goal is all the available naturally aspirated power, Kind of a hidden nook in the cranny. I feel like it adds around +10 rwhp with EVERY other NA supporting mod.
Old 02-20-2021, 05:54 AM   #10
NYblack1le
Mod list?
It depends on what you’re willing to spend to free up those last few ponies. I’m debating whether I should go hi ram now but I really don’t wanna cut up the car.
Old 02-20-2021, 08:11 AM   #11
Redlinez
Shifts under load
Redlinez's Avatar
Hi ram is the intake Pray's cars make the top numbers, I too ain't cutting my hood though. Ported MSD is the next step down.
22 Suzuki GSX-S 1000GT blue
Old 02-21-2021, 07:36 PM   #12
MrNoosNoos
yeah that's my main issue, cutting the hood. I'm not too fond of losing more visibility with a copo hood, plus at the end of the day its going to cost more than my ported MSD
Old 02-22-2021, 12:07 AM   #13
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
How much compression is everyone getting with the stock heads? TSP milled mine .030 but they said thats as much as they would go and wouldn't go any further. I run full time E85 and I want to be able to take advantage of it and get my compression up to around 14 or maybe 14.5.
cmitchell17 is offline   Reply With Quote
Old 02-22-2021, 10:24 AM   #14
RobbyBeefcake87
RobbyBeefcake87's Avatar
Drives: 2018 Camaro SS 1LE
I think the vfn looks a lot better than the COPO and you don't lose quite as much visibility since the cowl isn't as wide.
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler.
2018 Colorado zr2 - zr2 sport bar, showcase spare tire.
2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace.
2017 Corvette Grandsport (sold) - untouched.
2006 GTO (sold) - iat relocation, air box mod, monero side marker lights.
RobbyBeefcake87 is offline   Reply With Quote
