New PWR lt4 slanted intercooler bricks
So I took the plunge and ordered them but not without a little research and data.
On Jokerz performance website Brett said" our shop on a 2020 GT500 we switched out the factory intercooler brick to a PWR one & picked up 30whp & saw roughly a 10 degree IAT drop.Each core is hand made, welded and pressure tested. Good for 20+psi with zero collapsing.Improved air flow & efficiency. Cooler IATs." So I decided to email him to see if he had any data on the PWR lt4 bricks. I asked him if these bricks bring down Iat2 and manifold air temps while allowing more air to pass through and he responded with "Yes they flow 14 more gallons per minute at same pressure ratio as stock.Temps are 20+ degrees lower at wot then stock.The core technology allows for better water flow through the core for better heat extraction as air passes through a denser fin design that allows air to travel through . It all sounds good but I was still spectacle. It helps that Jokerz and Brett are well respected on here but I decided to give PWR a call and they said they have witnessed a have seen 15-30F reductions in IATs throughout a pull in all GM applications. I have a ported supercharger,Nick Williams 103 TB,2" Headers, Interchiller along with the FI thermal blanket and fasterproms supercharger thermal spacer (no longer made by them but FI interchillers started making the plates now). I will update everyone on my personal unbiased results as soon as I install them. BTW I have stock cam and heads and stock SP pulleys. I may end having the COOLEST stock supercharger...
![]() ![]() ![]() ![]() Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
Interesting. I’d love to see what you think after install. May have to look into these also.
Good thread |
![]() ![]() ![]() Drives: 2021 Camaro ZL1 A10 Join Date: Nov 2018
This is interesting to me as it seems you could see a benefit without a tune due to the cooler temps. Simple drop in. Too bad they are $1,800.
2021 Camaro ZL1 A10
2022 GR Supra 3.0 Past: 2018 Mustang GT Premium w/ PP1, MR, and A10 2007 MazdaSpeed3 1995 Pontiac Trans Am 1987 Camaro Z28 |
I know this is an old thread, but does anyone have any data on these intercooler bricks?
![]() Drives: 2021 Camaro ZL1 Join Date: Mar 2023
Yes, we need an update. I have yet to find any good first hand reviews and I'm curious.
2021 Camaro ZL1 Satin Steel Metallic
Rotofab CAI, Banks Idash, AEM X series wideband, CSP 2" headers, Jet hot 2500 ceramic coating, DSX Flex Fuel Sensor, DMS Fender Tank, Velossatech Big Mouth, JMS Fuel Booster, MPI Billet Lid, Jokerz race port, 2.30" upper, 107mm Soler TB, 160°F Billet DMS, Big Gulp, LPE Big Bore HPFP, XDI +30, ECM & TCM tuned by Elite Tuned, BMR Cradle Lockouts, Atturo 315 AZ850DR |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2024 CT5-V Blackwing Join Date: Sep 2020
If they worked well you would have known about them by now. Everyone would be using them.
#7 |
![]() ![]() ![]() Drives: 2019 zl1 6 speed Join Date: Jul 2017
To be fair, though, most people just swap superchargers and don't even try to make the stock one for efficient. So it's possible it could work, I know the supercharger spacers work , but many people dont talk about those either. That being said, if they're still $1600 or whatever, upgrading the heat exchangers might be more beneficial and cost effective
#8 | |
#9 |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
We tried them. We still use OEM bricks in ported blowers. They kept leaking in the front where the O Rings fit into the blower and there was no noticeable improvement in temps or power. We never used them again.
I think the only thing they can do is handle higher boost without failing like the OEM bricks can. But you won't get any gains from them over OEM.
GM Gen V Calibrator
#10 | |
#11 |
I have not use the blower spacers in my ZL1 but they were noticeably effective in my Hellcat.
#12 |
![]() ![]() ![]() ![]() Drives: 2023 ZL1 Join Date: Dec 2022
I had the FI Interchillers version of the blower spacers for my 2023 ZL1. Only for a short period of time before adding THSPI port injection. I did notice noticed IAT drop on average around 10°. I data log quite a bit when I'm just out cruising and my temps were down based on comparable driving and outside temps / weather.
Katech Track Day CAM 38%•BTR Dual Valve Springs-Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Ported Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper & ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI Interchiller Stage 2•THPSI Port w/875cc Inj•Dual Drop In Fuel Pump•DSX Aux Pump•Stainless Works 2" w/Legend NPP Axle Back•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout/Bushings Kit•DSS Chromoly DS•RPM 8-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
#13 | |
#14 |
See you at the Track!
Drives: 2022 Rapid Blue SS 1LE Join Date: Feb 2022
My question is, Why has Kong/DSX/etc not come out with a lid like the LS9 with upgraded bricks built into it? It seems like the LS9 design could be carried over to the LT4 with some modifications. It actually seems like there might be more room to work with on the LT4 vs the LS9, but I could be wrong.
https://kongperformance.com/collecti...ick-billet-lid Anyone know why something like this couldn't work?
2022 M6 Rapid Blue 1SS 1LE PDR (Current)
2022 M6 Rapid Blue ZL1 (SOLD) |
