Old 02-13-2021, 12:19 PM   #1
Jiyuu
Jiyuu
Jiyuu's Avatar
Drives: Camaro LT 2016
BCM / Tail light issues
Joined forum looking for some technical help with my 2016 LT.
2016 LT. Changed out tail lamps with LED lamps. I am aware that I will need to install the resistors or harness/with resistor.
My current issues are: (1) The driver side signal does not work at the tail light. The blinker on the console works 3 times normal speed then hyper flashes with matching blinker sound. The passenger side blinker does work with the same 3 blink hyper flash.
(2) The running light on the passenger side tail light does not work. The driver side running light does work.
I have confirmed the ground from each plug is good (pins 4 and 6).
I have also confirmed continuity from the plug to the BCM. Driver turn signal (plug pin 1. BCM X5-1) and passenger side running light (plug pin 5. BCM X5 -7)
Driver side blinker at plug pin #1 no voltage with blinker on. (Console blinker and sound on with hyper flash as mentioned above). Passenger side running light at plug pin #5 no voltage with light switch on.
I swapped the driver side and passenger side tail lamp assemblies and same problem above exists (so not a tail lamp assembly problem).
Also disconnected the battery over night to reset BCM. Problem still present.
I would think that installing the resistors or harness/with resistor will not resolve the left blinker or right running light not working? That leaves the BCM as bad or does anyone have any other potential items I may need to troubleshoot?
Thanks for any assistance!
Jiyuu is offline   Reply With Quote
Old 02-15-2021, 02:13 AM   #2
thebanks06
thebanks06's Avatar
Drives: 2016 Chevy Camaro 2SS
Check the fuses
thebanks06 is offline   Reply With Quote
Old 02-17-2021, 12:46 PM   #3
Jiyuu
Jiyuu
Jiyuu's Avatar
Thanks. Funny I did that but found I checked the wrong fuse. Checked correct fuse and it was blown. Replaced and blew again. Found wire connector between fuse block and BCM bad.
Old 09-05-2021, 02:41 AM   #4
Studiomax
Drives: 2016 Camaro SS
Im having this same issue.. Do you recall which fuse number you had to replace?
Studiomax is offline   Reply With Quote
Old 09-07-2021, 12:03 PM   #5
Nitefall17
Drives: Camaro 1SS A8 Vert
Put it back stock and see what it does....
Nitefall17 is offline   Reply With Quote
Old 04-21-2023, 10:01 PM   #6
s3rics213
1khp_1le
Drives: 2019 1LE/ss 2014 ss/rs summit white
Did you even figure it out?
s3rics213 is offline   Reply With Quote
Old 04-23-2023, 08:52 AM   #7
ctrlz
Some old posts here.
LED installs can be weird on this car. I believe cellsafemode is our guru on these matters.
I think there are some paths to ground which may need to be addressed.
