Old 02-12-2021, 01:24 PM   #1
DapperDan
DapperDan's Avatar
Drives: 2017 1SS A8 Nightfall Gray
Building an engine for boost
Looking for suggestions what would yall do? I will probably shoot for 900 to 950 whp , want it strong enough to beat the snot out of it every weekend without worrying about it .
Only wanna do it once. Would a factory Lt4 short block be enough? What aftermarket crank, rods&pistons? Stay stock cubes 416, 427? Stock heads with upgraded valves (what kind)or aftermarket heads? Thanks for the options
DapperDan is offline   Reply With Quote
Old 02-12-2021, 03:54 PM   #2
Choda
Drives: Turbo 6.2
Do you want to build the engine yourself or order one?
whatever power plant you decide, get ready to spend thousands on a fuel system.
2016 Twin Turbo Camaro SS - 968hp/970tq 8.9@153
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100
Choda is offline   Reply With Quote
Old 02-12-2021, 09:13 PM   #3
DapperDan
DapperDan's Avatar
Yeah trying to decide if I want to build or just buy one done. I've read people using drop in rods n pistons and then the crank screws up , or next they have valves breaking. Just wondering what others would do to make one strong as possible.
Old 02-13-2021, 10:48 AM   #4
RabbitZL1
Drives: 2018 Camaro ZL1
Being that I've done this (built my own motor), I would suggest calling someone like Thompson motorsports and get it built one time. Its easier, and theirs even comes with a warranty as long as they install the oil pump. If you have the ability to do it yourself, go ahead but i wouldnt use drop in anything.
RabbitZL1 is offline   Reply With Quote
Old 02-13-2021, 11:56 AM   #5
Choda
Drives: Turbo 6.2
I have bought a short block and built my own. Depends on your skill and amount you want to spend.
If you are building your own, I highly suggest having a machine shop balance the rotating assembly with the new rods and pistons. Its a couple bucks and a little bit of down time but well worth the outcome.
as far as valves in the heads, send your oem heads out for porting, valves and springs. Its much better to have the pros do it with your existing heads.
Old 02-13-2021, 03:14 PM   #6
laynlo15
Drives: 2022 Lt1 A10
I don't think there is a big advantage to building a 427 if your going to boost it, I'd build a 377 up to maybe a 408. I agree with Choda, GM has done a great job with these heads and will not require a lot of porting, but more of a clean up with new valves and springs. Some light porting will really make them flow much better but you can hurt power by over porting them also. Are you still going to run a Pro Charger?
Old 02-13-2021, 03:54 PM   #7
DapperDan
DapperDan's Avatar
Stepping up to D1X , +30 injectors, big bore hpfp, Aux low side,
Will run MS 109 / E85 not worried about pump gas ,90% drag strip maybe cruise night now n then. Do yall know the GM part number for a LT4 short block? Just bouncing thoughts around , I will get with Brett to finalize everything
Old 02-15-2021, 08:07 AM   #8
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I would just build your current block if it's in good shape. Rods, pistons, better thrust bearing...etc. You don't need more stroke for boost.
Old 02-15-2021, 09:27 AM   #9
Choda
Drives: Turbo 6.2
i agree. Order some nice rods and pistons with arp everything. Drop them off at local machine shop for balancing and assembly of the short block. Send your heads out for upgrades.
Old 02-15-2021, 01:50 PM   #10
laynlo15
Yup, if you were going NA then the 427 would be the best route but not boosted.
