Old 02-12-2021, 01:51 AM   #1
DirectInjection
Drives: Chevrolet Camaro
Question New 2021 Camaro 2ss rust?
I recently purchased a new 2021 Camaro and I noticed this rust, is it normal? I asked the dealership and they said it was normal. I figured this might be caused by the new design of the hood vent but I want to make sure. Name:  7C844E71-3586-47F6-86FC-D4D045B45620.jpg
DirectInjection is offline   Reply With Quote
Old 02-12-2021, 06:18 AM   #2
Drags1998
Drives: 15 SilveradoLTZ,162SSVert BlazerRS
I don't think its Normal,However, ! of the last tests for Any New car is a "LEAK TEST" Water is sprayed EVERYWHERE It looks like it was not cleaned up when they were done. That rusty pulley will be fine.
Drags1998 is offline   Reply With Quote
Old 02-12-2021, 06:31 AM   #3
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
Mine is 3 years old and doesn't have that, I guess its possible they sprayed the engine with water and it sat for a while. I would clean it all up and see if it comes back? Maybe a small leak at the water pump?
pauly1119 is offline   Reply With Quote
Old 02-12-2021, 06:38 AM   #4
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
I don’t think you have any issues but if will ease your mind take it back to the dealer and let the service manager check it out. Tell him/her that you have some concerns about the rust on your new Camaro.��
Old 02-12-2021, 06:58 AM   #5
Wrecks24
Wrecks24's Avatar
Drives: Camaro LT1
My 2021 LT1 looks exactly like that. just surface rust. Spray it with WD40 and wipe it off. Problem solved
2021 Red Hot LT1
Wrecks24 is offline   Reply With Quote
Old 02-12-2021, 07:02 AM   #6
Z28GTOSSMike
Drives: 2019 Camaro 1SS
My 2019 looked exactly like that when I picked it up. I figured it was from sitting on the dealer lot for a while. Looks like a normal engine with 22,000 miles now.
Z28GTOSSMike is offline   Reply With Quote
Old 02-12-2021, 07:02 AM   #7
Jeb114
Jeb114's Avatar
Drives: 2021 300
Normal some moisture spayed in. little WD 40 on a rag and wipe it off. Wait until you see your brake rotors after it rains....
Jeb114 is offline   Reply With Quote
Old 02-12-2021, 07:26 AM   #8
BrandanK
Drives: 2021 Camaro SS 1LE
While it is just "surface" rust now, it could quickly become worse.
It looks like the black oxide conversion didn't happen properly, or the part didn't get sealed properly after the conversion.
The process converts the top layer of metal to black oxide (Magnetite or Fe3O4) instead of red oxide (commonly known as rust or Fe2O3).
You can see that the serpentine system has already started throwing the red oxide on the surrounding parts. I would see if the dealership can swap the pulley. As others have mentioned, a coating of penetrating oil will help wipe it away, but wont fix the improper black oxide process.
Brandan
BrandanK is offline   Reply With Quote
Old 02-12-2021, 07:41 AM   #9
rayhawk
rayhawk's Avatar
Drives: Cadillac CTS-V
Brandan
There is nothing wrong with the black oxide, this is just on the surface. Black oxide will not stop rust completely, it has to be oiled if you want it to look nice. Replacing the pulley will result in the same thing after the pulley gets wet again. If it bothers you, you could wipe the inside of the pulley down with some light oil.
rayhawk is offline   Reply With Quote
Old 02-12-2021, 07:54 AM   #10
BrandanK
While I agree that the Hot Black Oxide process does not offer 100% protection against post process red oxidation; if done properly, it should offer more protection than this.
The part is brand new; in my educated opinion, it should not have oxidized this quickly.
Brandan
Old 02-12-2021, 08:00 AM   #11
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Factory GM harmonic balancers surface rust very easy. As mentioned above use something like WD40 on a rag will remove it.
Old 02-12-2021, 08:42 AM   #12
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
I agree with WD40 method. Too that's more likely dirty and grime that got went and settled there when the car was shutoff and long enough to dry. You really couldn't or shouldn't have gotten rust or corrosion at this point in the parts life
Old 02-12-2021, 01:39 PM   #13
sengli
sengli's Avatar
Drives: 2015commemorative vert 2SS
My last couple of new camaros looked just like that, especially if they were test driven when wet out. You should have seen the one I bought that was driven in the michigan winter slop!
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded
2015 commemorative vert 2ss
sengli is offline   Reply With Quote
Old 02-12-2021, 05:20 PM   #14
GrayLT1
My 21 looks like that as well.
GrayLT1 is offline   Reply With Quote
