Old 02-10-2021, 04:02 PM   #1
Markoz28
Drives: 18 ZL1 nightfall grey A10
A10 trans shift point?
When going WOT At what RPM does your A10 shift at?
Do you have trans unlocked and tuned?
Markoz28 is offline   Reply With Quote
Old 02-10-2021, 07:44 PM   #2
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
exactly 6500 rpm...if you use the paddles be sure to be ready to shift as you will hit the rev limiter
Old 02-10-2021, 08:04 PM   #3
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
And if it hits it in M, it'll fall on it's face... If you are running someone, stick it in D and let the computers win the race for you...
Old 02-10-2021, 08:50 PM   #4
Markoz28
So I was running data logs today. Put the car in manual 4th gear and went WOT from 2000-6600 and it shifted into 5th and kept pulling. I was trying to see if I can get the rpm up to about 6800 but it shifted on its own in manual right at 6600.
Old 02-10-2021, 09:20 PM   #5
2SS Capt
2SS Capt's Avatar
Wonder if that is a 10L90 thing in the ZL1, I was running down an onramp in my 2020 2SS (10L80) and was in Manual and was a little late on the shift from 1 to 2 and it fell on it's face...
Old 02-11-2021, 10:28 AM   #6
Reznap
Drives: 2018 ZL1
My 2018 Zl1 A10 falls on its face and won't upshift by itself. I gave up on trying to hit perfect shifts using the paddles as the lower gears are so fast you pretty much have to short shift or you end up at rev limit/fuel shut off.
Reznap is offline   Reply With Quote
Old 02-11-2021, 12:31 PM   #7
Ron_Robinson1
Ron_Robinson1's Avatar
Drives: A Static line to a pack tray & ZL1
Send a message via AIM to Ron_Robinson1
This cars shift at MPH, I think RPM has only a slight impact on it. This topic has been spoke on before.
But I could be wrong, I just know we have spoken on this, I can also post up picks of the rpm files as well.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4)
SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129
SOLD-2011 SS M6: Blower, Cam, Alky, LTs.
Ron_Robinson1 is offline   Reply With Quote
Old 02-11-2021, 12:33 PM   #8
Ron_Robinson1
Stock vs tuned Shift Points
This is someones stock file A10 shift points.
Old 02-11-2021, 12:34 PM   #9
Ron_Robinson1
Tuned
Tuned
Old 02-11-2021, 01:14 PM   #10
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
Originally Posted by Ron_Robinson1 View Post
Tuned
I’d like to tune my A10 to have more aggressive shifts, for non WOT driving....Perhaps in sport mode or track mode. As an example....I had a GTI that I could flip into sport mode and it would hold each gear much longer, as well it would downshift much more aggressively on deceleration. I really liked the feel and it worked well, even under light throttle. Albeit, the GTI wasn’t exactly a power house, but it was entertaining for city driving.
Would it be relatively easy for me to do the above to my 19 Z? I imagine it would really liven up my driving experience.
Sorry for the ignorance on my part....I have zero experience with tuning.
Old 02-11-2021, 04:19 PM   #11
Markoz28
My car has tuned trans and it shifts firm.
Old 02-11-2021, 05:10 PM   #12
Chutzpah
Chutzpah's Avatar
Thanks, I think I know what I need to do (did a bit of research) Sounds like I’ buy a new TCM from HP, remove mine, keep in case I screw something up. Buy a lesson guide, and credits etc. to tune.
Old 06-17-2022, 02:31 PM   #13
2020ZL11LE
2020ZL11LE's Avatar
Drives: Chevrolet Camaro ZL1 1LE: Stage 5
Is this pattern B?
Tuned
Hi Ron,
Is this pattern B?
I have had my ZL1's trans tuned after major engine upgrades and the track mode is not operating as it did with the stock tune. Wondering if these are you shift points for pattern B, which is track mode.
Thanks,
Kevin
Katech Stage 5, Magnuson 2650R, Max effort CAM, Johnson 2110-K Spec Lifters, Trend 3/8-.080 Pushrods, 103mm Katech throttle body and Snout, Billet Valve Covers, Billet Oil Pump, 160 degee Thermostat, 2" ARH long tube headers, catless 3" to stock NPP muffler, Big Gulp, CNC Machined Heads/Head Chambers, Griptec Upper and a bunch of other goodies!
861 RWHP
723 RWTQ
2020ZL11LE is offline   Reply With Quote
Old 06-17-2022, 03:11 PM   #14
Mac7504
Mac7504's Avatar
Drives: 2003 Monte Carlo SS SLP, 2022 ZL1
The A10 will not allow for an over-rev correct? Such as shifting to a much lower gear.
Mac7504 is offline   Reply With Quote
