Old 02-08-2021, 07:55 PM   #1
0025_SS
Drives: 16 Camaro 2SS Supercharged
Car wouldn't start after doing pulls
I have a 2016 Camaro 2SS A8 with 37k miles.
List of mods are as follows:
Supercharged Magnuson TVS2300
TSP Headers 1 7/8 no cats, DEI heat wrapped
K&N Air Intake
LT4 Fuel Pumps, HPFP and LPFP
Snow Performance Methanol Injection Kit
ATI Super Dampner Crank Pulley
DSX 230mm Underdrive Pulley for the Blower
Borla Atak Axle Back
BMR Lowering Springs
Car makes around 600 wheel horses on 14lbs of boost and around 617 ft-lbs of torque.
A week before my pulls I arced the battery trying to jump start it using reverse polarity as a mistake when attaching the jumper wires. It was a quick touch and go when that happened. We then found out the starter has failed. Replaced it and she starts again.
Then, during the pulls my car suddenly won't throttle anymore but instead slowly the RPMs go down. I stopped near an exit to figure out what happened. My temperatures were higher than normal, I had no leaks, there I thought I overheated. The only check engine light I got was from a Cam Positioning Sensor and 02 Sensors which I get sometime an issue happens with the car. After a few attempts on starting, car turned over and died the same minute with a different idle. Then started again a couple more times.
I now got my car at the shop that built it, they replaced the positive terminal fuse, and charged the battery. Still we got nothing. They are about to replace the starter again and we will see if that is our problem.
If not, can anyone help me please? I am very frustrated at this time. The shop is recommending me to bring it to the dealer if the starter is not the issue.
0025_SS is offline   Reply With Quote
Old 02-08-2021, 08:32 PM   #2
FarmerFran
FarmerFran's Avatar
I am sorry but, how do you mess that up?!?!?!?!?!?!?!
Old 02-08-2021, 08:38 PM   #3
0025_SS
I don't know if it was too much boost, overheating, electrical or mechanical.
Old 02-08-2021, 08:39 PM   #4
FarmerFran
FarmerFran's Avatar
I mean mixing up the
Red/Black
That is like elementary stuff in car terms.
Old 02-08-2021, 08:44 PM   #5
0025_SS
I was tired and stressed from work. Then the red and green anti-corrosion washers were in the wrong places.
Old 02-08-2021, 08:48 PM   #6
FarmerFran
FarmerFran's Avatar
bummer, as for your issue, electrical gremlins can be hard to find. Maybe something go zapped.
Old 02-08-2021, 09:04 PM   #7
0025_SS
I will keep digging to find out what it is.
Old 02-08-2021, 09:04 PM   #8
supercab78
Drives: 1931 Ford 1941&1963 Chevy. 2020 LT1
If it is cranking but not starting it's not the starter.
supercab78 is offline   Reply With Quote
Old 02-08-2021, 09:06 PM   #9
ex-SS-ve
ex-SS-ve's Avatar
Sounds like the polarity got reversed on something permanently. Hope nothing got fried and its simple. A friend did that on his fox body years ago and had to change pcm, harness and a bunch of relays.
ex-SS-ve is offline   Reply With Quote
Old 02-08-2021, 09:11 PM   #10
0025_SS
Did it fix his issue?
Old 02-08-2021, 09:50 PM   #11
ex-SS-ve
ex-SS-ve's Avatar
His car was good after that.
Old 02-08-2021, 10:19 PM   #12
19 2SS
Drives: 2019 camaro 2ss
14 pounds?? How long have you been running that much boost
2.9 Whipple, CSP longtubes, borla atak, lt4 fueling, dsx aux pump, big gulp, nw 103mm, zl1 rep wheels, Toyo r888r
19 2SS is offline   Reply With Quote
Old 02-08-2021, 10:57 PM   #13
0025_SS
Around 6 months now.
Old 02-09-2021, 08:48 AM   #14
L78toLT1
L78toLT1's Avatar
While not relevant with regards to your current issue, you should be making well over 600whp if you're running at 14psi
Baby Blue
boost, crank, electrical issues, starter
